Question about Ingersoll Rand HVLP Gravity Feed Spray Gun # 270G
270g where can i find a 1.3 or a 1.4 nozzle for my IR 270g paint gun???
We are having trouble getting the spray gun to pull the paint through. It will spray air but does not spray paint.
when you pull the trigger can u see the needle moving backward? if so, then it's either the paint is too thick compare to the nozzle size or the passage for paint is blocked. try to take the nozzle, needle and the cup off and give it a good clean!
Sep 05, 2011 | Campbell Hausfeld Husky Gravity Feed HVLP...
Bought anCampbell Hausfeld airless paint sprayer,
no fluid gets to nozzle or comes from nozzle.
sounds like your fluid line is pluged or the gun is pluged at or before the tip
Dec 28, 2009 | Air Tools & Compressors
I have binks model 21 automatic guns on my striper i installed rebuid kits when testing with water the guns drip water from liquid nozzle but not from needle it seats properly is this normal and will not...
If it is leaking fluid from the holes in the nozzle then the tip is not making good contact with the seat, the seat of the nozzle could also be dinged, or the tip / gun gasket might be bad. If the water is coming from the needle / nozzle seat, the needle or inside seating area of the nozzle could be nicked.
Nov 25, 2009 | Binks Air Tools & Compressors
BROKEN PART 270G
buy a new gun, parts wil cost as much as a new gun, beside having to hunt forever for parts( all most impossable to find!)
Aug 05, 2009 | Ingersoll Rand HVLP Gravity Feed Spray...
Problem spray painting water based paint
I spoke to a friend who was a spraypainter in his last job, apparently due to the thickness of the paint, I needed a larger nozzle on the gun. I couldnt get a nozzle to suit this gun so I purchased another gun with a cuple of different size nozzles. All seems to be working fine now.
Nov 19, 2008 | Air Tools & Compressors
IR 210g - using thicker paint
i dont have so much as a solution as a couple of things you can try to figure out whats going wrong.
make sure your compressor can handle 10.5 CFM @ 50psi
hook up the gun and dry spray it to check for blockages in the air supply
if the air comes through strong and constant, fill the paint hopper with water and spray until empty
if the water comes through constant, add half of the hopper with paint thinned with penetrol or floetrol
if the paint is coming out weak or spotty, make sure the vent cap is open on the paint hopper
if the cap on the hopper doesnt have a vent, try spraying with the cap off or cracked a bit.
if that doesnt work take off the hopper and check the filter for blockages.
i suggest straining all your paint before pouring it into the hopper
Nov 19, 2008 | Ingersoll Rand Hvlp Automotive Spray Gun
Paint spray nozzle - how do I know which nozzle is which - external mix or internal mix?
top one should be paint flow and the bottom one should be air flow. that is how my gun works anyway. Hope this helps you out. mine is a siphon type gun may be different for a gravity gun. Mike
Oct 22, 2008 | Air Tools & Compressors
Heat Guns Safety tips
Although safer than using a naked-flame blowlamp, care is still required when using a heat gun. Specific point are: * Because of the power of these tools (up to 2000W), when an extension lead is necessary, only use a lead rated at 10 amp or greater and always completely unwind the lead. * Never obstruct or cover the air inlet grills. If the air flow is reduced the heat gun will overheat and possible catch fire. * Never operate the heat gun with the outlet nozzle hard up against a surface, this will reduce the air and can have the same effect as obstructing the air inlet grills, * Do not use a heat gun near inflammable materials. * Always switch the tool off before putting it down on any surface. * Allow the tool to cool before storing it. * Do not place the nozzle next to anything whilst it is hot. * Never touch the hot metal nozzle with clothing or skin. * Do not use for stripping lead-based paints. * Do not allow any paint to stick to the nozzle - and if some paint does stick, allow the gun to cool down and remove the paint. * Do not look down the nozzle while the gun is turned on. * Do not insert anything down the nozzle with the gun.
Aug 27, 2008 | Master Heaters 200-300DEG 120V MASTER HEAT...
Ingersoll Rand  HVLP Gravity Feed Spray Gun # 270G Logo
29 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
