Question about Powercam Bluefox Extreme BF-401 Bluetooth Headset - Wireless Connectivity -
Bluefox BF-401 looking for device drivers
How to pair my BlueFox Extreme BF-402 with other phone
With the headphones powered off, hold the centre control button for exactly 8 seconds, until a single bleep is heard and the LED indicator flashes alternate red and blue. Another bleep will sound when the pairing is complete.
Jun 08, 2014 | BlueFox Extreme BF-402 Over-the-Head...
I have bafo-bf-1284 usb to parallel converter but i don't have driver cd. problem creating to install this product in windows 7 or windows xp please help me.
The BF-1284 driver (zip file) is available from BAFO support: http://www.bafo.com/menu-support.asp . Scroll down the list to the desired product. The driver is for Win98se and Windows Me. You shouldn't need a separate driver for Win7; the drivers should be in the OS. (See the link on Windows 7 compatibility near the top of the URL given above.) I suspect the driver should also be available in the OS for XP.
If your computer doesn't find the driver automatically, check if the driver is listed in Windows Update as optional updates. (You may have to manually check for updates.)
I hope this helps.
Jul 30, 2011 | BafoTech BAFO BF-1284 Parallel Adapter
I need to get an operator's manuel.
At the website www.samsungcamera.com site you can download the manual and the driver for the Samsung Digimax 401 and the Digimax 4010 which are the same camera.
To get there go to the site and click on SUPPORT then at the bottom of page select page number 9 or in SEARCH type in 401 which will take you to the Digimax 401. DON'T FORGET THE DIGIMAX MODELS 401 AND 4010 ARE THE SAME. I proved it since I compared my 4010 manual to the PDF for 401 and page per page identical. You will have to select a language for the manual and assume also for the camera driver. I found that the Samsung site was not user friendly when I first used it looking for the 4010 model which is not listed but the 401 is there.
Hope this helps.
Dec 14, 2010 | Samsung Digimax 4010 Digital Camera
Bafo bf-1284 can't detect
I need a driver for BF-1284 in windows xp
Aug 29, 2008 | BafoTech BAFO BF-1284 Parallel Adapter
Reqd Software for BF-810
Go to
this page at Softpedia.com
and follow the link to download a free copy of the driver for the BafoTech BF-810.
Mar 17, 2008 | BafoTech BAFO BF-810 Serial Adapter
I cannot install BF 810
The problem is two-fold: correct device driver for the endoscope, and correct driver for the adapter.
Please check with the manufacturer of the endoscope whether that connection expects a standard RS-232 port. They might be able to recommend the proper driver combination to get this to work.
Dec 22, 2007 | BafoTech BAFO BF-810 Serial Adapter
Driver problem
Check this site for the driver you are looking for:
http://www.bafo.com/menu-support_part01.asp
Or:
Sign up at this site and find the driver you are looking for
http://members.driverguide.com/ums/index.php?action=r&ib=1
Hope that helped
Dec 08, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
Bafo BF 2010
Yes, it does: Mine worked well with a fire wire and Hd of 160 gb maxtor: Now I,m trying with a 320 gb western digital and I 've the same problem you have. try again, it must work
Aug 21, 2007 | BafoTech 1 Bay BAFO BF-2010 Storage...
Problem with BF-810 usb to serial
windows xp can not install a driver for bf-810 adapter.
Dec 17, 2006 | BafoTech BAFO BF-810 Serial Adapter
Powercam Bluefox Extreme BF-401 Bluetooth Headset - Wireless Connectivity - Logo
32 people viewed this question
Top Powercam Radio Communications Experts
eradiostore
eradiostore
Are you a Powercam Radio Communication Expert? Answer questions, earn points and help others
