Question about HP LaserJet 3055 All-In-One Printer
Black shadow on the right and left side of the paper.
    New Friend:
  • 37 Answers
There are parts in your toner cartridge that needs to be replaced - Probably the PCR or the Drum,dont try to do it yourself- take it to a specialist.
Posted on Jun 15, 2009
1993 honda shadow 1100 where is the turn relay?
!986 - under the right side cover above the battery, I think at 1994 it is under the left side cover and it is a small black plastic box, and when you turn the signal on you can here "tick.tick.tick", if this tick is to fast, then one or more bulb is bad.
Jun 15, 2014 | 1993 Honda VT 1100 C Shadow
HONDA SHADOW 700 1984 REAR TURN SIGNAL, LEFT SIDE has 3 wires coming out , one red and two black. Can't find where the second black one is connected to. Only can find two connectors.
two in the harness running back through to the fuse block and one (black)should be bolted to the frame back there somewhere. Good luck!
Nov 17, 2011 | Honda Motorcycles
HP LaserJet 4Plus - just changed the fuser and rollers - was getting smudges and shadow on the printer paper. Now getting (on the left 1/4th of the page) light areas with little or no print. The shadow...
Take the toner cartridge out of the printer. Shake it side to side. Reinstall it and print something.
See if that fixes the output.
Could also be the transfer roller.
Jun 28, 2011 | HP LaserJet 4 plus Printer
Shadows on lcd
Why does my lcd proton Television have a long black streak on the right side of the screen?
Sep 25, 2009 | Televison & Video
Shadow along side
does this shadow go from top to bottom on the left or right side app 1" to 2" wide ? if so your light engine needs to be replaced
Jan 17, 2009 | Toshiba 46HM95 46" HDTV
Printing
It almost sounds as if the guide on the left side has been moved. Reload the paper so it is up against the right side of the paper tray and then move the left guide up against the paper.
Judy F.
Aug 28, 2008 | HP DeskJet 6122 InkJet Printer
HP Color Laserjet 3500 printer - no black on left side of page
The folded paper solution for for me. Thanks to all for sharing!!!!
I had the same problem. No black or cyan on the left side of the pages. From this advice... I folded a stack of 4 pieces of paper in half and then half again. I took out the transfer unit and put the folded paper in the upper left corner and then put the transfer unit back in. WORKS BEAUTIFULLY! Thanks you all sooooo... much!
Sep 25, 2007 | HP Color LaserJet 3500 Printer
Shadows appear when printing out
Heating unit (fuser) 's teflon roll is dirty causing ghosting. Either replace with new heating unit (it is on front top near paper output) or clean it.
It can be cleaned carefully with electonic cleaning spray (non grease) WITHOUT using any force (be patient) wiping with cloth and spraying again and again utill it is clean. Then spray silocone spray to cloth and wipe teflon with that.
Open unit: Remove mains and usb/network leads. Remove paper holder (printed papers) from top back. Under that you'll see small arrows on both sides. Push screwdriver to hole and release locks. After that you can raise dark lid from top. Under that on white lid there is 4 screws, open them. Open all back cover scews and take the cover out lifting from bottom edge. Open 1 screw from right cover (where network socket is. Lift white top cover a little bit and then you can open right side cover (from back to forward). Under cover there is flat cable coming from display unit. Open it and then you can remove top white lid. Push the rest of dark paper holder backwards (on top) and it opens and you'll see the power supply under that. When looking from back there is 1 screw at right holding black plastic roller plate. Open the screw and bend the plate to left (looking from back) Now you can see 50% of brown teflon roll that is around the heater lamp. Clean it with spray and cloth pushing CAREFULLY from bottom to top.
Do NOT push teflon horizontaly as there is nothing on back of teflon and it may broke. Underside there is a metal plate under teflon and you can use LITTLE force for wiping. You can rotate teflon pushing white gear at top (from top to bottom, it turns only this direction). When totally clean, wipe with cloth sprayed with silicone spray.
I do not know how long this helps (just did it by myself) but the printing result is perfect again with same color casettes than before.
Sep 13, 2007 | HP Color LaserJet 2600n Printer
How to fix black shadows appearing on both sides of the screen?
i beleive its electrical problem (horizontal circuit). if u are not inclined with this job just bring it there and besides they will give you warranty for their work.
Jan 14, 2007 | Optoma RD50 Television
HP LaserJet 3055 All-In-One Printer Logo
63 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
