Question about Benchmark 11065 Popcorn Maker
Kettle does not work
Lights and stirring are working but as soon as I turn the kettle switch on the house fuse blows up. This problem started after a deeper clean up I did to the machine. The cord has a label that says 120V / 60Hz.
  • hrubensv Jun 15, 2009
    Hi gogandy,
    I did no disconnect any wire but could be some water on the wiring or circuit. I will let the machine dry for couple days. The electricity supply is 120v.
    HV
  • hrubensv Jun 20, 2009
    I let the machine dry for couple days and now is working. I believe it was water in the wiring.
    HV
  • 4 Answers
You have probably re-wired the switch incorrectly or there is water in the wiring and the circuit is shorting, causing the fuses to blow. Also, is your electricity supply 120v or 240v?
Posted on Jun 15, 2009
I turn it on and set it to 375. Why does it just keep blinking?
blinking green red light Electric Kettles Questions & Answers ...
www.fixya.com > Forum > Tags > blinking green red light
Electric Kettles blinking green red light questions and answers. Ask your blinking ...the kettle lights up but won't heat up, just bought it, the on switch shows red, but it isnot working...what to do? ... Chef's Choice 677 Cordless Electric Kettle.
red icon blinking Electric Kettles Questions & Answers - Fixya
www.fixya.com > Forum > Tags > red icon blinking
Electric Kettles red icon blinking questions and answers. Ask your red icon ... Light will not stop flashing Even after descaling and cleaning thoroughly the red lightflashes. Any ideas? ... "On" switch blinks, kettle won't heat Our 4-week old kettle juststopped working. When we ... Chef's Choice 677 Cordless Electric Kettle.
Dec 12, 2015 | Chef's Choice Kitchen Appliances - Others
How do I get the agitator rotate
The motor in the top of the machine should rotate the gear sticking out of the top of the cabinet when you turn the switch on. This gear should connect with a gear on the top of the shaft that sticks out of the kettle when the kettle is in the correct upright position and turning the stir rod.
Make sure the kettle is installed correctly, and the switch is in the on position. If the motor is not turning with the switch on, it is broken and should be returned to store if possible.
There are no repair parts for this brand popper, and they cannot be repaired.
Sep 03, 2013 | Nostalgia Electrics Helman Group CCP-510...
My kettle keeps blowing the circuit
If the fuse in the mains plug or MCB at the consumer unit / fuse box keeps tripping then there probably is a fault in the kettle element or switch. If the RCD is tripping (the safety device with the test button on it) then there is an electrical leak either due to a crack in the element or water has got into the wiring, switch or power cord of the kettle.
Allow the kettle to dry out in a warm place for a day. Also check it at another power outlet to eliminate any problem with the outlet you are using.
May 28, 2011 | Dualit 72300 Stainless Steel Cordless...
I need to order a kettle for my Old Fashion Movie Time Model CCP-509 and I don't know what size kettle it is and where to order it from??
Nostalgia Electrics CCP-509 Movie Time Popcorn Maker
  • Now for the finishing touch -- a full sized popcorn cart that makes delicious, old fashioned, movie house popcorn. The design is nostalgic, but the features are very modern.
  • Tempered glass window.
  • Large stainless 4 oz steel kettle with built in stirring system.
  • Warming light.
  • Kernel catcher.
  • Supplies compartment.
  • Safety Electrics, and easy to clean design.
  • Popcorn never tasted so good at home.
  • Makes up to 1.5 Gallons of popcorn per batch. 4 oz Kettle.
  • Storage compartment in base of unit.
  • Dimensions: 16"L x 19"W x 60"H
Feb 04, 2011 | Nostalgia Electrics Helman Group CCP-509...
I have noticed that when I have my dishwasher on, and kettle and water filter that the safety switch trips out, shutting down most of my kitchen. The dishwasher has it's own outlet and the kettle and...
all kitchen appliances should be on ground fualt outlets & breakers,If an appliance is on a g.f. outlet it should only blow that particular outlet so all you have to do is push the reset button.Outlets and lights should be on different breakers,so that if the outlet breaker blows you will still have lights
Oct 11, 2010 | Microwave Ovens
New GE electric kettle causes wall outlet to stop working.
Your electric kettle in drawing more current than your wall outlet's are made for. Not being able to read your current draw on your GE kettle I would guess you have a bad GE kettle and it needs to be returned to where you bought it.
Oct 09, 2017 | General (102105011) Electric Kettle
Fuse made a loud bang. Put in new 13a fuse and
Probably the wires inside melted together and now as shor circuit occurs it causes the fuse to blow. remove the bottom of the kettle and check the wiring. There's no rocket science, so you'll identify the problem after visual inspection.
Best of luck
Aug 07, 2009 | Tefal Elegance Brushed Chrome Cordless...
Trips circuit when you turn on the Kettle heat
When the fuse blows see what else in the house is out, maybe you have the circuit overloaded. Try putting the popcorn maker on a different unused curcuit to see if it still blows. Then you will know if it is the popcorn maker.
Dec 09, 2008 | Gold Medal 2086 Popcorn Maker
Red light's on... but no hot water!
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Nov 06, 2007 | Kitchen Appliances - Others
Kettle does not heat up
yes the coil that heats up needs to be replaced....
Nov 02, 2007 | Benchmark 11065 Popcorn Maker
Benchmark 11065 Popcorn Maker Logo
221 people viewed this question
Top Benchmark Kitchen Appliances - Others Experts
ray gallant
Tom Chichester
Bill Boyd
Are you a Benchmark Kitchen Appliances - Other Expert? Answer questions, earn points and help others
