Question about Cosco 10-T99 Crib
Need parts for 10-t-99 crib
No bolts included
Missing bolts and screws for assembly of bed
Most hardware stores including Lowes, carry a full line of bolts, metric and standard. Just take a side piece and a rail with you and the staff will help find what you need.
Aug 24, 2012 | Evenflo Jenny Lind Crib
NEED SCREWS AND BOLTS FOR A CONVERTIBLE CRIB
We can help you with those. Email us at parts@productsamerica.com. We have the bolts needed for both styles of the Emily crib. We will be happy to walk you through ordering parts. Our numbers are 800-205-9642 or 800-772-1041.
Apr 18, 2012 | DaVinci Emily Crib
I need to no what size screws n bolts i need for a evenflo crib model # 012616
You can contact Products America. We can help you with the screws and bolts you are needing for your crib. parts@productsamerica.com or 800-205-9642
Sep 24, 2011 | Evenflo Jenny Lind Crib
I lost my manual, I need to know how to transform the crib into a toddler bed
Converting a Simplicity Crib into a Toddler Bed:
Please note, Simplicity has gone out of business and the Simplicity Cribs should NOT be used as cribs. They were sold at Walmart, Target and BabiesRUs. The word on the street is that Walmart is the easiest to deal with when it comes to returning them. Those who wish to return Simplicity cribs don't need a receipt, they can just take them to Walmart for store credit. BabiesRUs was apparently giving about $65 while Walmart was closer to $190. Again, this is just what I have heard from others.
You can find the specific information on the Simplicity recall here.
If you do want to use your Simplicity crib as a Toddler Bed, I have not read any warnings against this. Again, I might just take it to Walmart anyway and get a store credit and perhaps buy a new convertible crib. You can get some great ones on Amazon for around $150 with delivery included.
I would pack it up, take it in for store credit, and get a new crib!
You can get some great deals these days on cribs, there's a great one on Amazon for $150 with free shipping so it's kind of a no-brainer.
As I have heard, Walmart will take it back, no questions asked and no receipt necessary and you can get a brand new one with brand new parts, brand new instructions and no recalls or risks!
Good Luck.
Here's one of my favorites:
mkd123_2.jpgGraco Sarah Classic 4-in-1 convertible bed
If you still want to convert it, here is what you need to do:
1. Remove the front panel of the Simplicity crib. Use an Allen wrench and 45mm bolts (there should be extras underneath the crib, along with an Allen wrench, but if there aren't then you can pick some up at your local hardware store.)
2. Check the mattress support. It needs to be in the lowest position available, which will allow the toddler to get in and out of bed easily. It is also the only position that will make the rails line up properly with the pre-drilled bolt holes. To lower the mattress, unscrew the four bolts from the four corners of the mattress support and slide the support down. The holes for the lowest setting are just about the bottom wood panels. Use your Allen wrench to reattach the mattress support with the same bolts you pulled out when the mattress was in the higher position.
3. Attach the toddler bed rails to the crib frame. Use two 38mm Allen bolts on each rail. There are pre-drilled holes in both the rail and the crib frame. Line up the holes and then loosely screw the bolts into place. The bottom of each rail has a metal L-shaped hook. This will slide under the mattress support. Use a 19mm Allen bolt to attach this piece to the mattress support. When everything is lined up and screwed in loosely, go back and tighten each bolt. Repeat on the other side.
4. Check the entire crib frame for loose bolts. Use the Allen wrench to tighten all the screws. Toddlers can be rough on their beds, so it is important to make sure the bed is safe. You should recheck for loose bolts often. Jumping and climbing on the bed can easily loosen the bolts and screws.
5. Don't forget to hang onto the front panel and store it carefully, you will need it later to convert the bed into a full sized bed.
Jan 23, 2011 | Simplicity for Children 4-in-1 Convertible...
I need replacement parts for my crib.
any hardware store will have the parts you need; just take a sample bolt and, nut to them and, they will find them for you. these are not a special part exclusive only to your crib.
Jul 22, 2010 | Storkcraft Baby Baby Gear
Replacement parts
Good luck. These cribs use specific bolts and any others may damage the bed. I looked up Fisher Price Emerald Bay Crib and found nothing. Call Fisher-Price and see if they can sell you a set. 800-432-5437
May 08, 2010 | Fisher Price Emerald Baby Crib
I need to find the bolts for the jenny lind crib and the instruction book on the crib to make sure it is put together appropriately how do i go about obtaining these products
Products America supplies a wide selection of crib hardware, including an extensive line of fasteners. In order to determine the correct screws required for your crib we will need to ask a few specific questions. Please call us when you are with the crib for direct assistance at 800.205.9642 or 800.772.1041.
Oct 03, 2009 | Evenflo Jenny Lind Crib
Instructions for crib
it's a pain but take the parts of the crib into the hardware store that you need bolts for... make sure the sharp edges are on the outside when you put the bolts in.... i would suggest aircraft bolts... not horridly expensive.... they are the kind that will not come loose on their own.
Robert
Jan 22, 2009 | Baby Gear
Missing parts (pali spa crib set)
Questions about PALI? Give Baby Cribs Plus customer service a call at (800) 349-9131, Mon-Fri 8-9, Sat and Sun 10-5 EST or e-mail us at service@babycribsplus.com
Jan 16, 2009 | Pali Katie Crib
Here is Pali toll free number 877-725-4772 It helped me when I had missing screws
Sep 04, 2007 | Pali Sabrina Crib
Baby Gear Logo
Top Cosco Baby Gear Experts
Jennifer Rock
Jennifer Rock
thegtw
noel
noel
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
