Question about Pelco Cameras
Need pin out for 6 pin monitor conection for a Pelco color ccd camera model # ccq1400a-4
3 Suggested Answers
SOURCE: need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Posted on Jan 07, 2009
  • 33 Answers
SOURCE: what type power supply do i use for navco ccd
suprised it didn t come with it unless it was an option extra try there website to get the correct and order it from them or find a comprable one from radio shack knowing the correct voltage it should also say in your manual take take with you some camera stores might help you also
Posted on Aug 10, 2009
Tip
Pelco PMC10A Monitor 10 INCH COLOR HIGH RESOLUTION
We bought 6 Pelco PMC10A Color Monitors and they are working 24 hours a day. Suddenly after the warranty was over, the screen went totally black on 3 of them. After searching a while for the cause, Pelco seems to have used the wrong capacitor on their board close to the fly-back. They used a catalytic capacitor G-LUXON 4.7uf 50v and they have all busted by just looking at it on the board. I replaced the defect capacitor with a 4.7mf/250V Metallized Polyester Film Capacitor for about $2 each. They are now fixed! Hope this will help someone that has the same problem as I did.
REF: http://cgi.ebay.com/4-7mf-250V-Metallizd-Polyester-Film-Capacitor_W0QQitemZ220150073474QQihZ012QQcategoryZ4662QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
on Dec 03, 2007 | Pelco Pel Monitor 12" B/W
What kind of charger do jvc camera have?
IT's a little thingy you plug into the little hole on the camera.
Then you plug it into the receptacle on the wall!
Nov 04, 2012 | JVC Refurbished GZMG630RUS 1/6-inch 800K...
THE DOME CAMERA MODEL KDSQOOP1 (ULTRAK) IS STUCK ON ONE POSITION WITHOUT ROTATING EVEN IF YOU USE THE JOY STICK. wHAT IS THE PROBLEM?
If the problem is not hardware related than its likely your missing a software update. You can find the software updates on Pelco's website or trouble shoot with fellow techies & tech support at www.pelco.com/community - doubt your still going at it after a year but good information never hurt :)
Mar 28, 2011 | Pelco DF8CB Pg 1V21A Domepak Pendant Color...
What do I need to conect my CCD-TRV35E to my video player
You need RCA pins AV cable and if your video player has scart input then get scart adapter so AV cable plug in scart adapter and it will be hooked in video player.
All these info are mentioned in user manual of camcorder. Click Sony Support to download free copy of user manual and check page-7 and items 6 and 8 that needs to connect camcorder with video player.
Thanks.
Jul 14, 2010 | Sony Handycam CCD-TRV35E Camcorder
On the monitor there is a small little camera
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} That is not coming from the camera...They don't put anything like that out. Check the OSD settings of the device the video is going into. If there is On Screen Display setting with in the device (DVR, MUX, Matrix Switch, ECT)....if that doesn’t work then check the monitor menu to see if its a display feature you can turn off...good luck and let me know if this helps just remember the pelco camera will not push any graphic out except in the case of a PTZ where you will see the Protocol information text...
Jul 09, 2009 | Pelco DF8CB Pg 1V21A Domepak Pendant Color...
Need adaptor for older Sony analog camcorder - CCD-TRV70 DC 6V
You need to get a Digital to Analogue converter such as the Canopus ADVC110 A/D Converter. (circa $225). There may be cheaper alternatives. (you might also be able to use a digital camcorder that has a built in Analogue to digital converter):
 Canopus 77010150100 ADVC110 Converter
The Canopus comes with a 6-pin firewire cable. Since your Dell Studio has a 4 pin Firewire (actually called iLink) you will also need a 6-pin to 4-pin cable or an adapter:
 Firewire 6-PIN To 4-PIN Cable
 Cables To Go - 27028 - Firewire 6-Pin Female 4-Pin Male Adapter
You hook your Sony up to the A/D converter with audio and video cables (usually supplied with your camcorder) and hook the converter to you Dell with a firewire cable. Then you capture the video using some video capture software. I don't know what comes with windows these days.
Jan 22, 2009 | Sony Handycam CCD-TRV308 Camcorder
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
Cameras Logo
185 people viewed this question
Top Pelco Cameras Experts
Marvin
Marvin
Are you a Pelco Camera Expert? Answer questions, earn points and help others
