Question about AVC Computers & Internet
Sleep mode How do you get the sleep mode off
  • etrc_new Dec 24, 2014
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what is the make and model of computer ?
guide2u
  • 461 Answers
SOURCE: won't come out of sleep mode
Is this monitor connector to PC? is yes most probably the problem is the system is not sending signal to tell your monitor to wake up...
Posted on Aug 30, 2007
  • 2072 Answers
SOURCE: Sleep Mode
Yes there is.But let me give you an explaination of somethign in the scanner.Once you turn the power save mode off, If the copier has sat for a while and saws WARMING UP, It is not the power save setting. The scan lamp also has to reach operating temperature for the machine to run. So even after Power Save is off, you may get an occcasional Please wait Warming up before a copy. There is no settings or changes for the scanner lamp warming. I throw that in so you don't suspect you did something wrong in changing settings.
Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  1. Press the [Enter] button. 'Machine Setup Tray 1 Size' will be displayed.
  2. Press the [Left] or [Right] arrow button until 'Power Save' is displayed, and then press the [Enter] button.
  3. Press the [Left] or [Right] arrow button to select 'On' or 'Off' to enable or disable the Power Save mode.
  4. Press the [Enter] button to save the setting.
  5. If Off is selected, skip to step 9.
  6. If On is selected, press the [Left] or [Right] arrow button to select the required time interval.
  7. Press [Enter] to save the setting.
  8. Press the [Stop] button to return to the Standby mode.
Posted on Jan 11, 2008
  • 148 Answers
SOURCE: Disable sleep mode
To change the sleep mode: Press Menu Numbers 1, 8. From your key pad select the amount of time before the fax goes to sleep. 0 - 99 Press Set Press Stop/Exit You can find the user manual here for the future if you would like: http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000082/FAX4100_US_UG_0.pdf Hope that helps... Lbcoaster
Posted on Jun 27, 2008
  • 285 Answers
SOURCE: Monitor goes into Sleep Mode immediatly upon turning on computer
Ok. I think "sleep mode" means that your monitor might not have a tight connection. Tighten all connections. Also, push the power button on your tower. When you gegt back, go to screensaver- power settings- and from there you can adjust.
Posted on May 24, 2009
SOURCE: monitor goes into sleep mode
how do you go into the control panel when the monitor won't get out of sleep mode???
Posted on Feb 20, 2010
Why and how does my fitbit flex go into "sleep mode?"
You can enter or leave the "Sleep mode" by tapping the Flex rapidly for 1-2 seconds. You'll feel a vibration and the LEDs will blink. (The blinks will depend on if you are entering or leaving sleep mode.) In this mode, the Fitbit Flex reduces the LED intensity and doesn't give alerts. Afterwards, it will provide some data about your sleep pattern - length, movement, waking up during the night. This can help you determine the quality of your sleep. (Note: it isn't a replacement for consulting a doctor if you always wake up tired.)
I hope this helps.
(You can manually enter your sleep and wake times into the app without using "Sleep mode". Then the app will use the movement data from the Flex to determine sleep quality. However, LED lights (primarily blue frequencies) are known to reduce sleep quality so dimming them helps most people sleep better. The alerts will also interrupt your sleep and reduce the quality.)
Jan 11, 2015 | Fitbit Flex Wireless Activity & Sleep...
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
Screen will not come out sleep mode
Sleep mode? I have been fixing Garmin units since 2007. I have never heard of sleep mode. Can you be more specific?
Aug 11, 2013 | Garmin nuvi GPS
I am unable to access the internet from sleep mode Can only get on internet from shut down mode
Three possible causes of sleep mode. first, an extensive screensaver with password lock prevents display. A condition that is observable as a blankscreen also known as sleep mode. Second, a computer power saver settings that shutsdown during idleness. Third, An improper shut down of the computer would have caused a sleep mode to save the system data files.
Restoring the computer to regular functionalioty
First solving predictable sleep mode settings
1. A movement of mouse pointer across the screen should reestablish unprotected password modes
a. password protected sleep mode would display an promp message requiring key code soon after the mouse pointer has changed direction
sloving unpredictable sleep mode settings
1.A computer power saver, screen saver, or splash screen displays prevnting programs acess would require manually powering off the computer system.
a. A manual power back on of the system should restore to program functionality mode
important notes
1. contact expert technical assistance
Dec 20, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
My machine is also set to sleep mode and cannot rcv. faxes!
Sleep mode does not affect the reception of faxe check receive settings instead
Aug 28, 2009 | Brother IntelliFAX 2800 Laser Fax
Curious - What is the moon shaped key all about
this button puts the computer into sleep mode.
FROM WIKIPEDIA-
Sleep mode can go by many different names, including Stand By (Microsoft Windows 95-Server 2003), Sleep (Mac OS 8)-(Mac OS X) / (Windows Vista,Windows Server 2008), and Suspend (Linux). When placed in this Sleep mode, aside from the RAM which is required to restore the machine's state, the computer attempts to cut power to all unneeded parts of the machine. Because of the large power savings, most laptops automatically enter this mode when the computer is running on batteries and the lid is closed.
Though Sleep and Hibernate are generally thought as two separate functions, modern Macintoshes, Windows Vista (termed Hybrid Sleep), and some specially configured Linux machines also feature a variation of Sleep mode that incorporates the strengths of Hibernate. The RAM is copied to the hard drive before sleep mode is initiated, preserving the RAM contents in the event of a power loss.
ACPI is the current standard for power management, superseding APM and providing the backbone for sleep and hibernation on modern computers. Sleep mode corresponds to ACPI mode S3. When a non-ACPI device is plugged in, Windows will sometimes disable stand-by functionality for the whole operating system. Without ACPI functionality, as seen on older hardware, sleep mode is usually restricted to turning off the monitor and spinning down the hard drive.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 04, 2009 | HP Computers & Internet
UNABLE TO REMOVE SLEEP MODE
you can't take it off of sleep mode. the only thing you can do is set it to go into sleep mode anywhere between 0 to 99 minutes. you do that by pressing "menu, 1, and 8." there, you can input how long you want sleep mode. no way of completely disabling. i'm thinking that somehow, it must have gotten set to 0 minutes.
hth,
razors
Mar 30, 2009 | Brother IntelliFAX 4100 Laser Fax
Sleep mode
A drive in sleep mode doesnot shorten the life.But old drives in sleep mode are still passively active and reallocating the bad sectors of hard disk. so New disks have no problem. but once bad or weak sectors develop then its unsafe to make it go in sleep mode.
Oct 08, 2017 | Western Digital 120 GB USB 2.0 Hard Drive
Turn off sleep mode, It causes prob. turning on programs to use computer
I have a hp desktop, each time I push the sleep button, the computer goes to sleep, however about 10 seconds ofter entering sleep mode it starts up again.How can I make the computer stay in sleep mode. thanks
Oct 13, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
69 people viewed this question
Top AVC Computers & Internet Experts
David Payne
David Payne
Are you an AVC Computer and Internet Expert? Answer questions, earn points and help others
