Question about Samsung NX1000
When i turn my samsung camera NX1000 and take off the cap, there is a black screen . this just started happening and i have had the camera for about 8 months
There is a black screen when i try and take a picture. Even when i try to take a picture it wont let me, all that happens is that it will try and focus (you can hear it trying to focus) but nothing happens, i have tried EVERYTHING and i need help.
Same problem iam also facing.did you find any solution for that?2 weeks back only I bought this camera
Posted on Aug 28, 2014
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
My Samsung nx1000 used to have burst and continues setting on the drive as well as single and timer now only single and timer show up I don't know why
Check the mode wheel in your upper right.. check manual ,if all of the modes has all of the options.. I think the mode setting is the solve to your problem.. if that is a software problem, then you can just try to reset by removing the battery and restarting it .. or if the problem persists ,then go to the nearest service center to help you out.
May 19, 2015 | Samsung NX1000
When I try to take a picture the lense shows an error and makes noise
Noise can be because of dust or mechanical error
Apr 19, 2015 | Samsung NX1000
Samsung nx1000 not uploading photos to facebook
Buy another camera...Samsung is no good
Apr 16, 2013 | Samsung NX1000
My JVC-GRd72 camcord - error cap lens error when cap is NOT ON
Replace the CCD base Assy on the optical block assy.
Sep 27, 2009 | JVC GR-D30U Camcorder
Black screen
The issue is likely a bad lens assembly. Consumers wishing to repair this can check ebay for a replacement lens assembly, motor and sensor are usually included.
This happened to my Samsung s700 while I was mucking with it recently. It can happen when the lens meets severe resistance while trying to open, thus damaging the lens. The camera turns on and cannot tell precisely where the lens is, and subsequently the camera leaves the CCD imaging sensor turned off.
Replacement is easier than repair as lots of intricate parts are involved. However, the centermost ring will pop off with a little force, revealing four screws. The screws on the back side of the lens assembly are pretty obvious. Best of luck to anyone trying to fix this rather than replace it...
Apr 04, 2009 | Samsung Digimax S500 Digital Camera
Samsung L100 wont turn on
Samsung's have notorious problems with their lens-cap shutters malfunctioning. This seems to be the case with yours. It will have to be serviced, I'm afraid.
Mar 30, 2009 | Samsung L100 Digital Camera
SAMSUNG LCD TV (broken high voltage inverter?)
Sometimes a TV screen will illuminate for a moment when first turned on and then go black. Sound will be OK. Check electrolytic capacitors in low voltage power supply. There will be 2 to 4 around 1000 to 2200ufd. Inspect for caps that look like the tops are swollen or are near sources of heat. What happens is the inverters that illuminate the screen draw a lot of current when the TV is first turned on. Power supply cannot supply the amount of current needed with defective caps. Inverters will then shutdown and not try to restart until TS is turned off then back on. Checking output voltages will look normal when measured with this symptom. Caps are cheap and easy to replace.
Sep 14, 2017 | Samsung Televison & Video
Screen Is Black
there are two possible problem of your camera..1 may be the iris is not opening..try to look at inside of the lens you should see the iris will open when you turn off and on the the camera at the camera mode..if the iris in opening the 2nd problem maybe is the image sensor is deffective..in this case you have bring it to the service center....
Aug 29, 2008 | Samsung 1.5MP High-Definition Digital...
BLACK SCREEN
As a battery saving method, Sony typically puts a button on the camera body that allows you to turn off the screen. You will still be able to take photos but you will have to use the viewfinder. This would be the first thing to check See #8 on the diagram.
Nov 30, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Samsung NX1000 Logo
214 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
