Question about Laser Tek Services Sam-Ml3470 Black 1 Ml-D3470B Samsung Ml-3470 High Yield Black Toner Refill Kit Also For Samsung 3471 3470A 3471Nd Ml-D3470A Printers And Cartridges
Sportello fuser aperto
What that mean and how to solve
RICOH FT 4615,ANALOG ERROR 54. wHAT DOES IT MEAN?
first check if there are any soot of toner inside the fuser,you can either replace the whole fuser assembly or fuser thermofuse/thermister to solve your problem
Nov 19, 2014 | Ricoh Office Equipment & Supplies
Error code 005-301
Please try the following
- Lift the cover to expose the flat bed scanner glass.
- Under the cover, there is a long white bar with two white tabs perpendicular to the white bar.
- One of the tabs could be retracted. Pull on the tab until it is fully extended.
Error "Cover Open 005-301 Close ADF Cover" and solution is Close the cover of the ADF
Jul 23, 2014 | Dell 3115CN
Call Service 6000: 0037842
Call service in the 6000 range describes a problem with the fuser of the machine. you did not mention the model number of the machine, but on some of the machines this can be reset in the sevice mode under u163. Unfortunately on some of the smaller machines this will mean a fuser replacement.
Dec 14, 2013 | Kyocera Office Equipment & Supplies
Sulla mia lavastoviglie indesit de 74 evolution mi appare il codice di errore a12 mi sapete dire cos'?. Grazie in anticipo Fabio
Ciao Fabio.
A12 significa che c'e' un problema con il circuito di riscaldamento dell'aqua. A12 appare quando il modulo di controllo rileva che il circuito che include l'elemento e'aperto.
Elemento e circuito devono essere testati con il multimetro. Se l'elemento e' aperto deve essere sostituito. Se i cavi e l'elemento sono a posto, allora il problema e' il relay integrato nel modulo di controllo.
Il caso piu comune consiste in un elemento diffettoso.
In bocca al lupo.
G.
Dec 08, 2011 | Indesit 24 in. DE73 Evolution...
50.1 means that the fuser temperature is not reaching operating temp.
50.1 is a common error, majority of the time the fuser is not bad. This problem is solved numerous times by replacing the entire LVPS (Low Voltage Power Supply). But it could also mean that the fuser is bad.
Try this first:
you can fix the LV Power supply if you have a soldering iron. The solder connections open from heat. Just go around and hit all the suspicious looking ones, mostly the ones that have larger pins. They are the ones that carry the current to the fuser.
If that fails, then it is the fuser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 26, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
I faced error ##322 on my fax canon L250 how can i solve this problem. What is this mean how can i solve it.
Error 322 means that your fuser is not heating. For most cases it means that you have a bad fuser module, and needs to be replaces. Send your unit for servicing at any Canon-approved servicer.
Mar 03, 2011 | Canon FAX-L250
Got message engine fusion low heat error I replaced the fusion unit in early 2010, do I need to replace it again?
Low heat means the the fuser is not reaching operating temperature. The fuser may be bad, it could also mean that your voltages from the power supply are low. But , yes it is probably the fuser. The one you replaced in 2010, should have warranty, depending on where you purchased it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 01, 2011 | Office Equipment & Supplies
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on ecks80@hotmail.com and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
Machine error E04-01
error e04-01 means fuser warm up temperature
problems could be
-fuser thermister dirty ir defective
-fuser lamp is disconnected or defective
-fuser thermostat is defective
Oct 17, 2008 | Panasonic Workio DP-4530 Copier
Canon IR2800
e000007 is related to the fuser..you need to change the fixing film or clean the sensor
Sep 07, 2007 | Canon imageRUNNER 600 Printer
Laser Tek Services Sam-Ml3470 Black 1 Ml-D3470B Samsung Ml-3470 High Yield Black Toner Refill Kit Also For Samsung 3471 3470A 3471Nd Ml-D3470A Printers And Cartridges Logo
201 people viewed this question
Top Laser Tek Services Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Laser Tek Services Office Equipment and Supply Expert? Answer questions, earn points and help others
