Question about Sunbeam Electric Skillet Fry Pan Cord and Griddle Heat Probe
Electrical lead need a replacement lead
Western digital lap top drive does not seem to spin at start up 160 gb
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
hope this helps you
Nov 28, 2011 | Western Digital Scorpio WD1600BEVS 160 GB...
Windows 7 can't recognize harddisk anymore
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this helps you
Sep 15, 2011 | Toshiba (MK3259GSX) 320 GB SATA II Hard...
One of the bootable device has not been found.
your operating system is looking for somewhere to boot from
make sure there no disks in your drives
hope this helps you
Sep 10, 2011 | Computers & Internet
Just not detected on my computer
hope this helps you
Sep 01, 2011 | Computers & Internet
My TI-83 PLUS will not power on.
hope this helps you
Aug 21, 2011 | Computers & Internet
Control wont work completly dead
also check the Cmos battery and computer ram make sure they are securely seated with no dust built up or in the sockets
hope this helps you
Aug 13, 2011 | Computers & Internet
Motherboard NO Power
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
hope this helps you
Aug 07, 2011 | Mercury Computers & Internet
ASUS DSBF-D Dead, no startup, fans dead, just 1 green led on MB.
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
hope this helps
Jul 18, 2011 | ASUS DSBF-D/SAS Motherboard
There is no power on the motherboard, dont want to boot, the power supply is ok I check but is only 300mhz, maybe is not strong enough?
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps
Jul 18, 2011 | MSI 865PE Neo2-PFS Motherboard
Power supply is ok but no pwer on
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this helps
Jun 03, 2011 | Foxconn A6VMX Socket AM2+ AMD Motherboard...
Sunbeam Electric Skillet Fry Pan Cord and Griddle Heat Probe Logo
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
