Question about Fisher and Paykel Refrigerators
Code 128 what does this fault mean
Tip
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are...
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stands as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4 , 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13.
on Apr 17, 2010 | Electrical Supplies
Tip
Decoding Fisher & Paykel Electronic Washing Machine Fault Codes
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stand as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4, 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13 which is a pump fault.
Once the code is determined, search the web for the meaning and indicate it when requesting for an online assistance to facilitate a quick and precise response.
on Apr 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
ECU 128 just showed on our 2007 Allegro.. What does that mean ??
Usually problems like this are indicated by code ECU 128 which is a general fault code for coolant sensor, injector, EGR or temperature sensor issues.
Oct 03, 2014 | RVs
I have a Volvo 670 2007 D12 and I keep getting fault codes ECU Maintenance MID 128 PID 27 FMI 5 and MID 128 PID 245 FMI 9. Does anyone know what they mean?
These code are specific to Volvo and you will probably need to contact a Volvo service department to have them explained.
Aug 23, 2013 | Cars & Trucks
Fault code PO128
Code 128 is telling you the engine temp is below the thermostat rating. Usually means the thermostat is stuck open and not making the engine warm up.
Dec 16, 2012 | 2004 GMC Envoy
Obd2 code po 128
P0128 means that your engine thermostat is more than likely faulty. The code description is engine operation below thermostat regulating temperature.
Nov 22, 2012 | 2005 Pontiac Grand Prix
Active faults 1 at startup screen
if you press and hold the mode button it should beep then you will get the component location. ecu 128 for example is in the engine- mid 136 is the abs. once you see that, press the mode button again and you will get the code. sid 123 for example- press mode button again and you will get the failure code. FL 02, could indicate when it is reading a high or low reading, short or open... etc. once you have the three parts of this code then you should be able to contact your local dealer to find out what the code means. Truck diagnostics are not always easy... active codes really just give technicians a place to start... hope this helps
Dec 16, 2009 | RTO Ho Herpa Freightliner Truck Tractor
Refrigerators Logo
24 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
