Question about Sony Televison & Video
Sony tv hook up to security camera
Using RGA cables
3 Suggested Answers
tickets1
  • 641 Answers
SOURCE: Lenovo Y530 the cable to connect TV
the thinkp[ad has a s video out..so i guesss id get a s video cable
Posted on Oct 11, 2009
tknalty
  • 121 Answers
SOURCE: How do I get TV to recognize audio from laptop....
Try the following:
1. Select System Preferences from the Apple Menu.
2. Select the Sound icon.
3. Click the Output tab at the top of the window
4. Highlight the option that is not the Internal Speakers.
5. Make sure the Output Volume is not set low and that the Mute checkbox is unchecked.
6. Close the Sound window. (via Red Radio Button, Top/Left of window).
Try it again and see if you get sound this time.
I hope this helps. Regards,
Posted on Feb 09, 2010
Ps3 goes to black screen then to normal
It could be as simple as your video cable going bad. Check to make sure the wire is in good shape and that the contacts and connections are secure.
I would say try using it with an HDMI cable (if possible) and see if the problem persists. You can also try and hook up another device (DVD player, camera, PS2, etc) to the TV input you are using now and see if it is the TV that is giving you trouble.
Jul 09, 2012 | Sony Playstation 3 (PS3) Console
How do I connect roku 2xs to sony trinitron tv
If your Tv does not have the HDMI port you can use the RCA cables. If your Tv does not have the RCA video/audio ports you will need an adapter from Radio Shack for hooking up a video camera to a cable Tv. This adapter will allow you to hook the Roku to the adapter with the RCA cables, then the adapter hooks to the Tv with a cable just like a cable box. This adapter is also a pass through for other devices like a cable box and or another DVD player. Hope this helps FixYa up.
Aug 07, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I USE TO HAVE A LAPTOP AND WAS ABLE TO DOWNLOAD MY PICTURES WITHOUT PROBLEMS. NOW I AM BACK USING A TABLE TOP COMPUTER, I HAVE THIS OTHER CABLE WITH A YELLOW & WHITE MALE IN-PUT AND THE OTHER END FITS...
Yellow and white pins cable is called AV Cable, it is to hook camera with TV. It wont hook camera with computer.
You need USB cable to connect camera with computer. Required USB cable is available in Sony Accessories Store under following part number..
319698101 .... CODE (USB 5P) CONNECTION
Thanks.
Jun 22, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
Try the following:
Feb 05, 2010 | Apple MacBook Pro Laptop Computer with...
Oct 11, 2009 | Lenovo ThinkPad T61 Notebook
Security camera hook up
Hi Boybest,
Yes it's possible.
You have several options with your TV. You can use the Video-In from the auxiliary/line in or even though a VCR. The plugs in this case use what are called RCA Jacks. They travel in three's, one yellow, one red and one white. The yellow is the Video.
Any hook up is going to be dependent upon the output from your camera. Security cameras, for the most part output a video signal much the same as a VCR. Some however use RF (Radio Frequency) which requires it to be attached to a cable or antennae jack and then tuned in (usually channel 3 or 4).
If it's a straight NTSC Video signal there should be no problem. A long cord with RCA jacks to the Video-In would do it. Then you could switch the channel to AUX or Line One (which ever your model uses) to get the camera signal.
Computer cameras have a whole different way of doing things. If you run into any snags, comment me back with the make and model of your camera. I'll get you up and running.
BTW, good things come to those who rate. ;-)
Hope this helps.
Mike
Feb 12, 2009 | RCA 20F420T 20" TV
Question on adapters for older tvs
What you are looking for is a Coaxial (or F pin cable) to RCA (or Composite) converter. You are going to need an actual converter...not just a cable ...because you actually need to convert the signal.
The biggest question is where do you get one of these things? I found one on line that I think would work for what you need to do. http://www.cablewholesale.com/specs/40x3-30400.htm
Check it out but before you order it, email them and tell them exactly what you want to do...or make sure they have a good return policy in case it doesn't work the way you think. Another option is to go into your local Radio Shack...they may have something that will do the trick.
Good luck!!!
Jan 28, 2008 | Sony (ICSSP20) TV Input
No voice
Make sure you are using the correct cable. Sony cameras come with a 3 prong RCA cable. These cables can also be purchased at your local Electronics store
Nov 15, 2007 | Sony Handycam DCR-TRV350 Digital Camcorder
I hook my cam corder up to the my tv it will play but no sound
You are likely using the S-Video cable (multi-pin cable that connects to the front of the camera below the spotlight). This cable carries video but not audio. To get audio, use the multi RCA to 1/8" adapter (has red, yellow, and white cables and plugs into the side of the camera)
Nov 20, 2006 | Sony Handycam DCR-TRV260 Digital Camcorder
Televison & Video Logo
11 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
