Question about Boating
Removing starter w/out pulling motor kawasaki jet ski 750 ss
Can you remove the starter on a 1996 kawasaki jet ski 750 ss without removing the motor?
    Champion:
  • 207 Answers
Yes but its not easy you pretty much have to take all the exturnal parts off carbs, exhuast airbox if u have one but it can be done make sure you have a swivle for your socketsbest place to get a starter is sbt.com short block tech
Posted on Jun 27, 2009
Need to replace starter bendix on 1994 750 kawasaki xir
It is fairly easy to change your starter bendix. Just start by disconnecting the battery cables. Then you will remove the bolts on the flywheel cover, which also hold the starter in place, and then just change the old part out with the new one.
Sep 25, 2016 | kawasaki 2010 Jet Ski Ultra 260X
Drive shaft removal
Not to be a rude or mean but perhaps you have taken on a job that is over you level of experience with a watercraft or that requires special tools or shop equipment. My knowledge as an auto mechanic tells me that the trouble may be due to items that are pressed together hydraulically. My best "guess" is to buy a service manual for the watercraft, follow the tear down for the shaft and bearings in question.
Aug 19, 2014 | WSM 1992-1997 Kawasaki Ss 750 Cc Jet Ski...
Kawasaki watercraft
compression check , 100psi or more ! battery and connections good ?
Jul 06, 2013 | WSM 1995-1997 Kawasaki Sxi 750 Cc Jet Ski...
I have a 1995 kawasaki ts jet ski it runs but goes really slow will not hit high end. i just got this jet ski it looks like the carb and lower end of motor is new. i did find some water in carb and cleand...
If the carburetor was properly cleaned including the teeter-totter float needle then you may just have accidentally changed the setting screws. Try setting the the high end and low end adjustment screws the standard settings are: Low speed screw: 3/4 turns out (+ or - 1/4 turn for fine tuning) high speed screw: 1 1/4 turns out (+ or - 1/4 turn for fine tuning) If the previous owner rebuilt the whole machine but could not figure out why the boat would not rev out, the next thing to do is remove the water box and and split the halves. http://www.bikebandit.com/houseofmotorcycles/1995-kawasaki-750-ss-jh750a4/o/m3253#sch27834 If a mouse nest has been built in the exhaust system the extra back pressure could be the problem. If the exhaust coupler has broken rubber tubes, has come apart, or has not been put together correctly that might also be the cause of the problem. http://www.bikebandit.com/houseofmotorcycles/1995-kawasaki-750-ss-jh750a4/o/m3253#sch29444
Aug 08, 2011 | kawasaki Full Suspension Mountain Bike Men
Kawasaki jet ski starter motor removal
To get access to the starter you will probably have to lift the motor out of the machine. Most Kawaski hulls do not give you much room to work. When you take the exhaust off you may have enough room to unbolt the starter.
Aug 24, 2010 | Encore Software Kawasaki Jet Ski...
Where do you read the mileage on a 1996 Kawasaki 750 sts jet ski?
I hate to tell you this but we go by hrs. the motor has ran for if theres not a hr.meter on the jet-ski you well need to istemate on how many hrs.it has ran.If you think maybe the water impeller needs to be replace,it won't hurt.better to replace then be stuck.
Jun 17, 2010 | kawasaki Full Suspension Mountain Bike Men
''how to replace starter in 1993 jet ski''
Unbolt the electronics box (swing out of the way), take off the box mount plate, and remove the exhaust upper manifold and expansion chamber. This should give you good access to the starter.
Jul 04, 2010 | 1993 kawasaki ZXR 400
How do you replace a starter on a 2003 kawasaki 1100 jet ski
You will have to unbolt and move the electronic box, unbolt and remove the upper exhaust manifold, and the expansion chamber . This should give you access to the starter underneath.
Jun 01, 2010 | Encore Software Kawasaki Jet Ski...
Boating Logo
1,003 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
