Question about Tell Me More Homeschool English, Complete Edition DVD-ROM
Initialise flash player
Could not initialise flash player when starting tell me more english
Alarm activated and is unable to deactivate
REMOTE KEY INITIALIZATION For this type of key.
The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM V. The initialization procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
Procedure:
1. Close all doors and have all keys available.
2. Using key number 1, turn the ignition switch to KL R, then switch off within 5 seconds and remove the first key.
3. Within 30 seconds of turning the ignition switch to "off" Press and hold button #2 .
4. While holding button #2 , press and release ("tap") button #1 three times within 10 seconds.
5. Release both buttons. The LED in the key will flash momentarily. The GM will immediately lock and unlock the doors signalling a successful initialisation.
6. If additional keys need to be initialised repeat steps 3 - 5 within 30 seconds.
7. Switching the ignition to KL R completes the initialisation.
SERVICE NOTE:
The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory functions activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
REMOTE KEY INITIALISATION For this type of key.
The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM. The initialisation procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
Procedure:
3. Within 30 seconds of turning the ignition switch to "off" Press and hold the arrow button.
4. While holding the arrow button, press and release ("tap") the roundel button three times within 10 seconds.
5. Release both buttons. The GM will immediately lock and unlock the doors signalling a successful initialisation.
SERVICE NOTE:
The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory function activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
Apr 08, 2014 | 1996 BMW 540i
Hi im new at this and not shure how to use this 4gb flash drive,i installed it in to the usb port and nothing came up ,can you help to tell me how you work it i have a sony pc with windows xp
Firstly, make sure you're logged in an admin account
  1. Click Start > Run
  2. Type diskmgmt.msc & press Enter
  3. If the initialisation wizard doesn't pop up automatically, scroll down the bottom half of the list to find your flash drive (starts with disk 0, disk 1 etc).
  4. Right click the unallocated space of the flash drive and click Format
  5. Follow the onscreen prompts.
If you can't see your flash drive in the list, try another USB port.
Dec 02, 2010 | Computers & Internet
When I put the sd card in and then turn power on it ask to format. no matter if I input yes or no the camera then shuts off
i have this w5 camera for the last 3 years few months back an error appear named E;91: like that and sometimes a beep sond for few seconds also on flash mode i cant take pictures i solved that problem by initialise the settings.now that problem started i initialise and formatted also remove the memory stick and again initialise and formatted but the error continues.i can only take pictures without flash what can i do please give me ur valuable suggestions
Oct 12, 2009 | DXG Technology DXG-572V Digital Camera
My flash doesn't work? how do i turn it on?
Have you tried resetting your camera? Powerdown and take batteries out. Then hold "power" button for 30 seconds, release and repeat couple of times.
Jul 08, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
My Sony Cybershot DSC W55 "7.2 mega pixel" does not flash. Error code E:91:01 ?
Please RESET your camera , go to Menu > Initialize > OK
If problem still exist you need to replace flash unit in camera.
Let me know if you need further help.
Jan 28, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Picture package problem
[File Name] Picture Package Menu Updater [PPMenuUpdateUS.exe] [Target Product] Picture Package 1.0 to 1.8 [Update History] Resolved the problem that "Picture Package Menu" cannot be started in the environment that only Macro Media Flash Player Version 8 is installed and Version 7 or previous is not installed. Download the update/fix at http://www.ppackage.com/e/dl_ppk_menu1x.html
Aug 15, 2008 | Video Cameras
Format a cd
First some explanations:
The Canon DC210 will only take 'minus' format DVDs (DVD-R, DVD-R DL and DVD-RW). Only the DVD-RW must be formatted (initialised) before use. During initialisation you'' be asked whether you want to initialise the disc in VIDO mode or in VR mode.
VIDEO mode: Once finalised discs recorded in VIDEO mode can be played back in most common DVD players, offering the best compatibility. However, recordings cannot be edited (deleted, rearranged etc) on the camcorder.
VR mode: You can easily edit the recordings on the camcorder. However, discs recorded in VR mode can only be played back with DVD players that are compatible with DVD-RW discs in VR mode.
My preference is Video mode - I can then play the disc on a DVD player and edit it on a PC.
Now, to initialise a DVD-RW
1. Press the 'FUNC.' key
2. Use the joystick to select 'MENU' - it's in the bottom left corner of the screen
3. Use the joystick to select 'DISC OPERATIONS'
4. Use the joystick to select 'DISC INITIALIZE'
5. Use the joystick to select either 'VIDEO' or 'VR' mode
6. Use the joystick to select 'YES' to confirm your choice
7. Use the joystick to select 'YES' to start initialising the disc
Close the menu only after the screen display returns to the 'DISC OPERATIONS' menu.
Don't forget to rate this solution once you've tried it !
May 11, 2008 | Canon DC210 DVD Camcorder
Tell Me More Homeschool English, Complete Edition DVD-ROM Logo
35 people viewed this question
Top Tell Me More Computers & Internet Experts
David Payne
David Payne
Are you a Tell Me More Computer and Internet Expert? Answer questions, earn points and help others
