Question about Proform Drive Motor Nordictrack Pt: 286633 C2250 C2155 C2255 C2100 C2150 A2250
Nordictrack C2150 smell burning motor hot
Electrical burning smell when using it. Runs fine. Could this be the motor?
Grinder motor: AC DC
If it was a DC motor it wouldn't run on AC. If it hasn't been used for a long while it might smell while the dust and grease burn also the bearing(s) could be dry, make sure it turns freely and smoothly and nothing gets too hot. Check current with ammeter
Apr 28, 2014 | Miele CVA610
Nordictrack c2150 panel not working
adjust the Reed SWITCH, see the diagram attached it. Clean it, test it of open or faulty. Tight the connector very well. Replace and clean the contacts batteries( if they have).
Tight the ribbon cable inside.
If the problem persist, after you did, replace control display board
God bless you099b95f6-0273-44db-b9a8-431d1bfaedf5.gif242bb3fe-383b-4bdb-aa92-fe8728465711.gif
Jul 25, 2013 | Exercise & Fitness
My nordicktrack exp1000 runs for about 20 minutes, starts to smell like its getting hot and will shut itself off, can I fix or do I have to buy a new treadmill
Step 1:
this happen because the lack of LUBE, do it
Step 2:
1) troubleshoot the main motor see my personal TIPS for motor help
2) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram.
Jan 08, 2013 | Nordic Track Nordictrack Exp 1000...
How to replace the walking belt on the c2150
see the video and proceed according at your common sense and logically: GOD BLESS YOU
Jul 25, 2012 | Nordic Track NordicTrack C2150 Treadmill
Nordictrack exp 1000 trips safety and stops abruptly...
Inspect belt and deck. The deck should be smooth without any grooves, pits, or exposed wood. The belt should have a consistent ridged feel from one side of the belt to the other (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Visually look at the underside of the belt. It should have a consistent look. Black streaks in the belt are a sign of bottom-layer wear through. Very worn belts will feel smooth in the areas you normally walk- you would think smooth is good but not in belts because the smoother the belt, the more contact area. Continued use of your treadmill may damage expensive electrical components. 85% of all Treadmill problems are cause by worn belt and deck I would revisit the scene of the crime again.
Jun 10, 2010 | Nordic Track Exercise & Fitness
Burning smell
There's a number of reasons to smell burning after a washing machine cycle. It's a 220V appliance, so if it short's out it will cause problems. It's more likely the motor being overloaded making it hot and causing the electrical burning smell, or a short that's overheating something electrical. Check to see if the belt that spins the whole barrel is melted or worn anywhere. Inspect the wiring that's attached to the system that engages spin, which is different from agitation by the big tower.
If these both check out, an trip to the Maytag Man might have to fix overloading motors or relays, or switches, if anything turns up in your search for the source of the electrical smoke. Ozone is what you are smelling, FYI.
May 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
My vacuum cleaner is giving off a burning smell.
if its a rubber burning smell check the belt and the brushroll. if its an electrical burning smell then dont use it. the motor is overheating and will eventually get hot enough to catch fire.
Jan 02, 2010 | Vacuums
I have a Ruud Acheiver 90, I'm having some problems, the rollout (burner) limit switches are opening, and there is an electrical burning smell. It seems that sometimes the squirrel cage isn't kicking on,...
Thanks for your question,
yup your fan motor is bad, if you need to manually start it each time then the motor winding are bad and it is not getting the air across the coils, which in turn are over heating, thus causing a burning smell, and then tripping your limits, you need to replace this motor ASAP, before it does cause a fire, if the limits ever fail !! I hope this was helpful for ya, if it was please give this a rating, thanks again,
mr.grzz
Jan 23, 2009 | Heating & Cooling
Burn Smell (electrical) from my GE WPSE4200A0WW
We have the same problem, and found out the the electric motor is running very hot. Replacing the motor seam to cure the problem, but the motor is not inexpensive. $200 to $350.
Sep 04, 2007 | GE WBSR3140DW Top Load Washer
Proform Drive Motor Nordictrack Pt: 286633 C2250 C2155 C2255 C2100 C2150 A2250 Logo
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
