Question about Audiovox VE1020 10.2 in. TV/DVD Combo
I need a under cabinet mount
I want to mount my TV/DVD but I don't have a mounting bracket
The VE1020 didn't come with a mount. It came with round plastic spacers (16) that were 1/4", 1/2", and 3/4" thick. You could stack these on the mounting screws to get the clearance you needed for under the cabinet mounting. You will note that there are 4 through holes for the mounting screws, one in each corner of the chassis. Sheet rock screws of different lengths will work. You can easily just cut four small blocks of wood or use 3/4" - 1" wood dowel cut to the length you need. Drill a through hole in the dowel. Paint them to match if they will be exposed.
Posted on Oct 07, 2014
I have a used microwave that mounts under a cabinet, Kenmore model 721. It has only two screws to mount through cabinet does it require additional hardware? Seems alot of weight for just two screws.
Kurt,
There is usually a mounting bracket that mounts to the wall and the microwave hooks into that and is held up by the two screws you referred to in your question. Unfortunately, you have not provided enough of the model number for us to look up any info to help you find a new bracket to mount to the wall. Hope this helps!
Feb 22, 2016 | Kenmore Microwave Ovens
What size Machine Screws do I need to mount a GPX Under Cabinet TV?
Um, "machine screws"? Unless you have a metal fitting inside the cabinet for those to screw to, you don't need machine screws.
Assuming you do have the metal fitting, then take that fitting to the hardware store to get the correct screws (and perhaps nuts). How long? Measure the thickness of the bottom of your cabinet, add the thickness of the bracket(s), and get the next size longer.
Jul 09, 2015 | GPX KCL8806DT 7 in. Portable Television
Wall mount Sanyo LCD-32xr8DA
look at the middle of the tv the 4 screw mount thats wre the tv wall mount gos. good luck
Jun 15, 2013 | Televison & Video
Want to mount tv lg 42lg50 42 in. on wall...which screws you use for drywall
You don't use screws for drywall to hang a TV, EVER.  That's a 50 pound TV.  You should only use the heavy stud bolts that came with mounting bracket and bolt them directly into the studs.  If by some chance the mounting didn't come with them, go to Home Depot or Lowes with the mounting tell them what you're doing and they'll get you what you need.  You are using a mounting bracket, aren't you? If by some chance you're trying to do this without a mounting bracket, STOP what you're doing and get a mounting bracket appropriate for your size television.  Go to Monoprice, they're the cheapest and their quality is excellent.  Meritline is good as well, they just take a little longer to get.  See the video below.
utube.png You-Tube video "lCNyc-KgCDY" placeholder [unremark-end]-->(do not delete) utube.png
http://www.monoprice.com/products/subdepartment.asp?c_id=109&cp_id=10828
http://www.meritline.com/tv-wall-mount---c-13552.aspx
Apr 22, 2011 | LG 42LG50 42 in. LCD HDTV
What size bolts do i need in order to mount it under the cabinet. the bolt that comes from the cabinet into the micro
mcdevito75 here, Best Bet bring the mounting bracket and bolts recieved with the unit to your local hardware store. they will give you the correct bolts need to mount undera cabinet.
Jun 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I am seeking a template for re-installing my 2 year old microwave. Jenn-aire has none of the templates in stock and can't send me a pdf or file so I can print the template myself. I have tried 2 parts...
Since you can't get a paper template for remounting your microwave, I can offer you my tips for doing this, as I've had to reinstall many of my customers microwaves, after they've done a kitchen remodel.
You can use the metal mounting bracket as your "new" template. Just unmount the micro and remove the metal bracket and you can then position it on the wall or under the cabinet where you are looking to mount the microwave. However, before you remove it from the wall, simply measure the distance from the edges at the top and both sides of the bracket, where it is presently mounted and you'll be able to easily remount it in a new location.
If you've already removed it from the wall, not to worry, simply place it on the back of the microwave and measure the distance from the edges of the bracket to the top and both sides of the microwave's canbinet edges. Allow for 3/16" additional distance and you should be able to then remount the bracket at the new location with ease.
Please remember that you want to get the bracket secured into a wall stud so it can hold the weight of the microwave once it's installed and fastened to the bracket. I also recommend that you use wall anchors at the side edges at both the top and bottom corners to help secure the bracket IF there are no wall studs behind the predrilled holes for mounting the bracket to the wall.
If you have trouble using the metal mounting bracket, you can always trace the entire bracket onto a piece of heavy paper or cardboard, but frankly, I find this unecessary and time consuming, since you've already got the mounting bracket right there with all the holes and such.
Also, don't forget to measure the location of the power cord at the top or back of the microwave and remember you'll need to drill a hole in order to be able to pass the cord thru the cabinet. If your microwave has screws at the top front edge that help secure it to the cabinent above it, again, simply measure the distance of these mounting locations from the sides and back of the microwave cabinet and drill holes thru the cabinet, using a drill bit that is twice the diameter of the mounting bolts. You should add washers to these bolts to help prevent the bolts from pulling thru the cabinet bottom.
Mounting a microwave is best done with at least two people, as holding it in place while someone else puts the bolts in it isn't easy to do by yourself. Also, it is much easier to do, when installing it over an existing range, if you move the range out of the way first, so you can stand under the microwave, instead of having to lean over the range while trying to install it. Not to mention the fact that should you drop the microwave, you'll not only damage it, but could destroy your range at the same time.
Hope you find this Very Helpful and best regards!
Oct 23, 2009 | Jenn-Air JMC9158AAS Convection/Microwave...
How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Jun 25, 2009 | Frigidaire FMV156DC Microwave Oven
Kenmore galaxy model 721 microwave hood combination
You put a mounting plate on the wall behind where the unit will be mounted. Then the microwave hooks onto the bottom of the mounting plate and you swing it up to the cabinet above it. Then you must screw 2 mounting screws through the floor of the cabinet above into the bracket on top of the microwave.
Jul 01, 2008 | Microwave Ovens
Need side mount brackets gpf65 because of granite counter top, model #ghda485n10cs ser# rm763786b, quietpower3 dishwasher
I don’t know your counter situation, usually you have to put dishwasher in a bottom cabinet and mount both side. Suppose you only have one side to mount, you have to go to home depot to buy a 90 degree metal mounting bar, mount the top part to your top granite support board, the bottom side mount to the dishwasher, it should be a ¾” plywood board underneath the granite, you can use ½” screw to mount it.
Hope this can help you,
Jun 25, 2008 | GE Dishwashers
Audiovox VE1020 10.2 in. TV/DVD Combo Logo
100 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
