Question about Pioneer SD-P62A3-K 62" Rear Projection Television
My SD-P6093-K Pioneer has recently stopped turning on. It makes a click noise as if it was turning on, but about 3 seconds later it makes another click noise and then then nothing. No picture no anything. I opened up the back to see if i could figure it out and when you try and turn the TV i hear the first click then the second click then a little red light turns on inside the TV.
  • Pioneer Master
  • 5,138 Answers
BAD STKs can cause this they are Big black ics will have part # on them,also check 6amp fuse if blowed it will not come on.
Posted on Jun 15, 2009
I just replaced the convergence ICs on my TV SD-P6093-K and found allot of miss information on the internet.
First of all the convergence card is not located behind the front speaker panel but in the back of the set. It is in on the left side of the panel with all of the various sockets. It has an L shaded aluminum piece attached to it.
Second some people claim that you can use STK392-180, STK4274-SL or STK4279-SL ICs. I don't know if any of that is true but I do know that the STK392-110 that was originally installed worked fine for many years and is available on the internet for as little as $6.00 each (you will need 2).
It is an easy fix if you know how to solder. Remember to use thermal compound on the back of each IC before installing.
Posted on Jul 11, 2009
My oven fan has recently started to make a very loud rattling noise for around 30 seconds once every few minutes while the oven is turned on in fan mode.
The fan needs be cleaned and lubricated. To do this: Turn off stove/oven. Remove fan cover plate. Remove fan. Clean and lubricate the shaft bearings with 3 way oil. Install fan and cover plate.
May 16, 2016 | Smeg Ovens
My SD-P6093-K Pioneer has recently stopped turning on. It makes a click noise as if it was turning on, but about 3 seconds later it makes another click noise and then then nothing. No picture no anything....
STK ICs 2 of them,example STK392-110.also CK hori out put transistor and little blue capacitor 2Kvolts it feeds back to Hori Transistor. Mats has STKs
1-800-628-1118 $10.95 each they retail for $55.00 each in repair shops.
Mar 16, 2010 | Pioneer SD-P62A3-K 62" Rear Projection...
I was watching tv and out of nowhere the tv turned off and now will not turn back on for more than a couple seconds. When it does turn on it makes a click noise then turns off, with no sound or picture.
Dec 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Had an electrical power failure during a storm when we lost power
there are no problem with the fuse if the pwer turns on then off ,,you should get some one to look at it ..unless you have electronic experience....hope this helps ..
Jan 01, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer SD-P6093-k Convergence issue
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Convergence procedure to many brands of projection TVs are given in detail.
May 19, 2017 | Televison & Video
Pioneer rear projection model # SD-P6093-K
HELLO. IT SOUND LIKE YOU HAVE NO HIGH VOLTAGE.!! COULD BE THAT YOUR HORZANL TRANZOR IS BAD & MAY BE YOUR FLY TRANSFORMER ALSO. !!! THEY WELL NEED TO BE REPLACED.!!! "GOOD LUCK" HOPE THIS HELP'S YOU!
Aug 19, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
Convergence board diodes
how about looking at the output resistors... also look at the fuses feeding the stks ussally if the blow the two fuses blow
Dec 21, 2007 | Televison & Video
Turning on SD-P403 Pioneer projection tv
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine.
Oct 30, 2006 | Pioneer SD-P50A3Q 50" Rear Projection...
Pioneer SD-P62A3-K 62" Rear Projection Television Logo
367 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
