If You are only one HDD connect then you make primary HDD jumper slot sat. And right direction data cable sat. And connect motherboard port proper.
Open Bios and check it HDD driver detect or not. If detect ok if problem then change data cable and power cable. Some diagnosis your problem solved.
no its not, sometimes that device or the port connection are not installed yet properly. To check it on the device manager, see to it that the connection on your Belkin Switch are functioning. Or try another port or USB connection, it might work there.
Do they work fine if you connect the keyboard and mouse directly? Does the video connection work correctly? Check that the appropriate ports are enabled in the BIOS (USB or PS/2).
Just go into the bios and insert the correct parameters. you shut it off before it could save the settings. Or hit fi on boot and it should take you into the bios and you cand sort it out in there. If you want an easy way, just do a system restore. Start,Programs, accesorys, system tools, system restore, just go back a day or two before you had that issue, and you should be good to go, good luck
Have a close look at the NIC assembly in both the computers.Simply link one computer to the other and see that it detects this or not. Alternatively bypass the switch and try to connect to the broadband from each PC. If u are able to access the net without the switch, then most probably the switch is conked out.Change the switch...................sodeep
