Question about Kohler Electrical Supplies
Kohler soap dispenser gets stuck in down position
Stuck in down position
  • 1462 Answers
SOURCE: Sticking dispenser drawer
no other way then force but having got it out you should try to estabish why it is sticking
Posted on Apr 01, 2007
SOURCE: Soap dispenser
I got my fixed last night. It was the "lid" for the softener despenser that was making the drawer stick. To remove it you need to take the top off of the washer. There is are two plastic "holders" on the back of the machine that hold the top onto the machine. Each of these "holders" have two screws, remove them, then remove the holder. You can then, with some effort, slide the top of the washer towards the back the then lift it off. You will then be able to see plastic tub that contains the drawer for the despensers. You can't remove this tub, but on the side facing the inside of the washer are a couple of tabs holding the top of the plastic down. You can gently release these tabs and pull up on the top slightly. This gave me enough "play" to then open the drawer. The problem, I believe, is that over time, that tub moves and makes it impossible for the drawer to open. With trial and error, I found that with removing the "lid" for the softener despenser, and completely closing the lid of the plastic tub, that that solved the problem.
Posted on Apr 05, 2008
jj505
  • 195 Answers
SOURCE: kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Posted on Mar 16, 2009
SOURCE: Soap dispenser stuck on LG WM2277HW
Great advice. I used a portion of you plan. Pulled off the top, but since the softener cup is on the right, I only uncliped the 3 clips on that side of the assembly. With those loose, I could pry gently up on the back portion of the assembly lid, and the drawer pulled out.
I also see no need for the cover, other than a measuring device. So removed the screws at the front, pushed the assembly back into the washer, and unclipped the rest of the lid. Once the lid of the tray assembly was off, it was easy to remove the softener cover. The only challenging part was getting the re-closed assembly to go back into the cut-out in the face metal. I got caught a couple times, but getting my hand up under the assemble allowed be to push evenly up on both sides as I pushed it forward into place.
Now the door works fine again. Seems to be a significant design flaw by LG.
Hope the helps other.
Posted on May 17, 2009
SOURCE: Maytag jetclean eq plus dishwasher: soap problem
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Posted on Jul 15, 2009
Kohler soap dispenser leaks onto counter
Your dispenser nut is either not tightened down underneath or your plastic base/o-ring needs to be replaced. Turn off water at value. Using sink nut removal & installation tool that is available at any Lowe's or Home Depot. Remove it and look at what is wrong. Conntact Kohler for free parts to repair it. Reinstall dispenser .
Mar 01, 2014 | Kohler Home
My Kohler soap dispenser is not pumping ?
Probably the chack valve is stuck either with hardened soap or a piece of trash. Wash out the assembly completely flushing everything with ample water. It should work after that.
Dec 08, 2013 | Kohler 74845 Replacement Soap Dispenser...
There is a cap from soap stuck in soap dispenser. water is backing up and out of dispenser, how can i retrieve it without calling a repair service
Push the tab next to the bleach dispenser down, pull out the dispenser drawer.
You should be able to find the cap and remove it. Simple fix. I would suggest if
you start the washer you may lose the cap down into the machine.
Feb 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
The door for the soap dispenser is stuck half open even after I ran it thru a couple of cycles
This may or may not be the answer you are looking for but I know with mine the soap dispenser will not close unless the outside dial is completely in the "off" position. Trying turning the dial clockwise very slightly. If you hear a click and it resets the soap dispenser position that should work. Otherwise I have no idea. :)
Aug 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Latch cover on dishwasher soap dispenser no longer functions.
hello there. i hope i can help you?. please check the latch spray a little wd40. and give the soap dispenser. a good clean with warm water. please check that you are useing the correct soap? as this can cause alot of problems. check once a week.top tip give the machine a good clean once a month. i hope this has helped you marymena? also please check for any little obstructions.
May 08, 2009 | Frigidaire Dishwashers
KOLHER Soap dispenser won't dispence soap.
Pull the dispenser out. Put it in semi hot water foe a few minutes to clean it. Then put the pickup tube in a glass of water and pump it untill water comes out. They get clogged with soap after so long.
Good Luck
Kurt
Mar 01, 2009 | Kohler K-5988-2-7 Entree Self-Rimming...
Kohler 5988 Sink leaks from soap dispenser spout (?) when dishwasher is running
Hi.. Its a breather or "vent "and its clogged. Remove the drain tube under the sink that runs from the vent to the connection on the drain( under sink). Clean vent and replace. Please send me some Positive feedback if I've help. Thankyou!
Jan 21, 2009 | Kohler K-5988-2-7 Entree Self-Rimming...
Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Nov 04, 2007 | GE Nautilus 24" Built-in Dishwasher
Electrical Supplies Logo
29 people viewed this question
Top Kohler Electrical Supplies Experts
rjivaro
John Trevino
Wayne McNeil
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
