Computer gets restarted
I Have Zenith Desk top. 600MHz P-III, 128 RAM, 40 GB HDD, ATX.
After starting my computer, if anybody moves the CPU Cabinate the computer get restarted.
This also happens when i try to insert Pen Drive, USB data cable or any other cable in back side of CPU Cabinate.
What can be the reason and what can be the best Solution?
    President:
  • 987 Answers
Pls check the cables if possible remove all cable from motherboard and reinser again ...they might be loose...
Posted on Jun 15, 2009
ASUS desk top wiring diagram
When it tries to start do you get any beeping, if so how many beeps?
Aug 08, 2014 | ASUS M51AC-US002S Desktop Computer - Intel...
Como configurar un ide para cable de 80, y mi procesador cambiode frecuencia
google translate
how to set up
an ide cable 80, and my processor ChangingEngineOil frecuenciatengo two discs, a 10 gb
my motherboard
is a Soyo SY-6vba133, I have a memory of 128 mb ram, a 64 mb graphic accelerator, a Pentium III 750Mhz, 10gb hard drive, a 40 GB hard drive, a DVD room, worked great ..., stop using 8 months, but now came back to light, but the settings change abruptly change my processor running at 500mhz frequency, 10 gb disk ide1 works well, but the disk of 40 gB, but with dvd room, it gives me problems, sometimes the DVD works, sometimes not, so with the hard drive, but when you restart the computer gives me information, that is not enabled for cable ide2 of 80 pine trees ... ? change settings as it was before leaving ...?
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Jul 07, 2012 | Soyo Slot 1 SY-6VBA133 Motherboard
Hi , my name is Nitin and the problem i am facing with my PC is that it gets restarted after every 10 to 15 minutes while playing games and it starts disk checking everytime it restarts. This happens even...
The following tip is not for the same model, but for the same kind of symptoms :
http://www.techsupportforum.com/hardware-support/motherboards-bios-cpu/183116-asus-p5p800-p4-3-0ghz-random-reboots.html
Dec 18, 2010 | ASUS P5QC Motherboard - Intel P45, Socket...
I have a old pc cotaining 1.7 celeron processor, 256ddr ram and 40 gb hdd. xp sp2 hang at 34munits remaining but win98 is perfectly. what can I do?
hello
windows xp mostly used minimum of 512 mb RAM. try upgrading your ram and check your fan and heatsink if it is seated properly on the cpu, because if the computer hang mostly the cpu is hot.
thanks
Nov 22, 2010 | Intel 845GE Motherboard
How to fix no signal from monitor to desk top ?
Plug in the monitor cable (blue head) to computer display car properly. If you find difficulty in getting display card, it is located at back side of Cabinate box (CPU Box) and try to match the pin orientation.
Aug 29, 2010 | Computers & Internet
Cursor is moving eratically sound is ver
chances are cpu may be running at 100% check task manager
Feb 07, 2010 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Desk computer overheat
hi there,
the thermal over heating is functioning, press F4 to resume on normal function then once the windows appear go to all program,
accesories and system restore click restore point, select a date that your pc run normaly
it will restore your pc on normal function you ca experience restarting and that the point it will restore your system.If still syntom persist
reinstall your windows system.have a niceday
regards
Jul 10, 2009 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Computer won't start
the problem was not the power supply, if you had a green light before.
motherboards will not start up if the motherboard (northbridge) gets too hot. This is to save your CPU from overheating. Make sure that the CPU fan is on, and you can leave your case open, and not in your closet, to stay cool long enough to order a more efficient case with circulation. You probably upgraded graphics cards too? The new ones run hot.
Jun 28, 2009 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Wont start up
I had those symptoms one time after I didnt seat my cpu in all the way into the mootherboard. Not saying a bad cpu is the problem, just a thought while you wait for more professional advise.
Nov 27, 2007 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Intel D850MV motherboard
If you hear no beeps and the led lights, and the fans stay on after striping all the components from the motherboard except for the cpu, and power supply, you have either fried your motherboard or your cpu. Its impossible to tell without more testing. I'm sorry but you either need someone to test it or you can buy a new computer (thats what I did). For about USD $300-$400 you can get a brand new computer with 500mbs of ram, 120gb hard drive and a 3 ghz cpu. If you look around you can get an even better deal.
Aug 15, 2007 | Intel D850MV Motherboard
Computers & Internet Logo
20 people viewed this question
Alun Cox
David Payne
David Payne
