Question about GPS
Depth reading is intermittent on Furono 1650 plotter
  • emuaus Jun 15, 2009
    I'll give it a go, thank you. Is the reset a separate function to resetting the factory defaults or one in the same?
    Scholar:
  • 106 Answers
Hi
just visit the website...my.boatus.com "It's not cheap at $300, but it was worth it..."
"We work with Furuno, so these enhancements will not void their factory warranty..."
"For anyone with the older units having problems seeing them clearly in daylight..."
"this might be the answer....
thank u rate me..
Posted on Jun 15, 2009
    President:
  • 1,383 Answers
There is 1 reset button on that fidn it and reset all settigns to factory defaults.
Aslo you can downlaod manual from here.
http://auto.owneriq.net/manuals/mfg/furuno_usa/furuno_color_dgpsplotter_color_gpsplotter_gp1650d_gp1650_furunonavionics_gp1650d_gp1650_furunocmap_nt.html
What is AppHangXProcB1 in my cutter plotter
What kind of plotter. Reading the error it appears that some process is freezing up. This can be caused by a corrupt print job, bad driver. First step you want to take is to update the firmware on the plotter.
Jul 23, 2016 | Office Equipment & Supplies
Why don't I see fish on my lowrance elite5 hdi fish locator
Sounds like you do not have your transducer connected.
You will know it is working if you have a bottom sounding. If you have a bottom sounding (depth reading) and it is correct then you may have to fine tune the finder to see the fish.
I have the same finder on my boat. http://njsaltfish.com/index.php/captainsfocus?sid=61
Sep 17, 2015 | Lowrance HDS 5 Fishfinder GPS Chart...
I am recording voice over work in my home studio. I am using a behringer mixer "new" with usb interface, a new NT-1 Rode mic, into a lap top with audacity installed. I am getting clicks, tall single
Sounds like a clock or bit depth issue. Verify what sampling rate and bit depth is coming from the USB interface, and make sure the laptop/Audacity is set for the same.
Oct 27, 2014 | Audio Players & Recorders
Need a repair shop for GPS,Fisher
Hi Clarence
Although the problem COULD be a faulty depth transducer, in my experience this is usually caused by a cabling problem, either there is a poor connection at the display unit, a poor power cable connection, RF interference from another device or the cable has been pinched causing an intermittent fault. After making SURE the power cable is tight, I'd clean the connections, then inspect the cable looking for an area that has been stressed. If you have a VHF radio nearby, try shutting that down during your testing. If depth reads normally, you know where your issue lies.
Good Luck!
-Steve
Oct 27, 2014 | Lowrance PARTS - LOWRANCE 15FT EXTENSION...
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Just updated to the last version 4 of firmware. Depth reading are wrong, say 48 meters when it's only 2 meters.
Check for depth offset, there may have been an unintended change that altered this setting. This setting compensates for draft....
Jun 21, 2011 | Lowrance HDS 5 Fishfinder GPS Chart...
How do I change the language setting on a Furono GP 1650 ?
sir
like to know how to change the furuno 1650 language setting
Nov 03, 2010 | Furuno GP1650DF GPS Receiver
I want to transfer data between my 1650 wf plotter and my compute
Yes and you have to get them from a Furuno dealer as they have to be purchased from Furuno. The cost is about $200. If I can be of assistance email me: kevin@sun-me.net
May 09, 2010 | Furuno 1650wf Gps Fish Finder Combo...
When I turn on the unit it will not read the depth only a blue screen and it will not let me switch out of auto mode or run the sounder test?
I know this is an old question but just ran across it. The 1833C/NT is a radar and chart plotter. It requires the external and optional black box sounder to have depth recorder functionality.
Oct 03, 2009 | Furuno 1833C/NT GPS Receiver
Wiring of seatalk instruments
OK, you are confused. Seatalk is a bus system, using 3 wires , (power +, power-, and Data.) red, bare and yellow repectively. So Red and Bare are 12V and ground. Since the 125 shows a green light, it is getting power and outputting data. but is it seatalk?? to make a 125 Seatalk, you must hook red and green together to 12 V, so check that first. if green is grounded or not connected, that is the problem (or one of them)
Next divide system to its' simplest terms, so hook the GPS straight to the display ST60, and see if it works red to rd, yell to yell and bare to bare (sometimes black) One by one hook the others into the chain until they all work or failed device takes down Seatalk network. If you are missing 12V on a seatalk leg, check 5A fuse in course computer. If you have a pilot, you have a course computer, unless it is ST4000 wheel pilot, and then the brain is the display (course computer is built in to ST4000 display)
Sep 01, 2008 | Raymarine RL70CRC GPS Receiver
GPS Logo
111 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
