Question about Lorex Eco 8-channel Dvr Security System W 4 Cameras & 13.3" Led Monitor
Newly added cams have red circle on screen like red m when theres movement
Picture is good but red circle
I pushed the audio only on my 55" RCA smart LED LCD TV and lost the picture Tryed the menu button to switch it back but now there isn't a picture to view the menu on How do I turn the picture back on
I suspect that when adding your audio cables you may have bumped another cable loose. If you look and don't see a loose connection, one thing that has helped me in the past is to just remove ALL cables completely (that means both sides of all cables from all devices) and and slowly connect one device at a time, checking that the newly added device functions properly before proceeding to the next device.
Good luck
Apr 25, 2016 | RCA Televison & Video
Tip
Digital cameras tip :lines and shapes
<p>We all bethink our geometry classes, bedeviled by circles, triangles, and snake-like curves. Applying these simple shapes to your accountable amount can advice to abridge circuitous scenes and add beheld interest. Consider aggravating to abduction an angel of a being walking bottomward a long, beeline street. Instead of cutting beeline bottomward the line, move yourself bristles or ten anxiety to the ancillary and shoot that alley at an bend - accepting that band bridge through the intersecting curve of the abstract tic tac toe lath from the aphorism of thirds can actualize the apparition of movement as they advance the eye through the picture. S-curves are alike added dynamic, while repetitive curve can additionally actualize movement of the eye through the picture, like repeating after-effects of bank on a bank or alongside row houses forth the ancillary of a road.
on Dec 23, 2010 | Cameras
Big red circle in the middle of the picture
Your light engine is bad and needs replaced. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Apr 30, 2010 | Hitachi 51F59 51" HDTV Projection...
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Apr 16, 2010 | Sony Cyber-shot DSC-S980 Digital Camera
How do i use my webcam on acer 5532
You don't have a web-cam on your Acer Aspire 5532. Sorry, I actually bought a brand new Acer Aspire 5532 with Windows 7. It's really nice but that little black circle at the top of your screen is not a camera. I do believe you can have one installed though.
Good luck,
Brandonmxb
Dec 08, 2009 | Acer Aspire 3610 Notebook
Screen deactivated & a red circle with an 'X' flashing
First turn your firewall off (if you have one). You need to go into your 720 with the TomTom Home software and erase the downloaded software (with the remove items from my device) and reset the device (little reset button under the unit keep it pressed for 5 seconds), place it back in the cradle and restart your computer and than restart the 720 , bring the TomTom Home program up, and when the TomTom Home software in your computer restarts and detects the 720 it will tell you that you need to update the application, if it doesn't than you force the update by going to the add maps option, select items on my computer, select applications and press the add button, when done, go back and to device (option in top of your screen) and select disconnect device, restart your 720 and it should be back to life with the upgraded software.
Aug 01, 2009 | Tomtom Go 730 GPS
On my c-765 slow shutter speed
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
May 03, 2009 | Olympus Camedia C-765 Digital Camera
53UWX10B Red giving problems
Good Day,
Welcome to the world of having a convergence circuit problem. There two things you can do; get it repaired by a Factory Authorized Service Center or repair it your self. Purchase KIT 10 from B&D Enterprises, 1-800-458-6053. The kit has everything you will need except soldering equipment and experience. Good Luck, big IRISH.
Sep 19, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Intermittent blank screen with r,g and b semi-circles at top of screen
the blinking standby light should be a help. It should be blinking a repeating code. Can you post that here please?
Thanks,
Dan
Sep 09, 2008 | Sony KP-46V35 TV
Lorex Eco 8-channel Dvr Security System W 4 Cameras & 13.3" Led Monitor Logo
18 people viewed this question
Top Lorex Computers & Internet Experts
David Payne
David Payne
Are you a Lorex Computer and Internet Expert? Answer questions, earn points and help others
