Question about Kwikset 909 909-15 Satin Nickel Smart Code SmartCode Signature Series Touch
Back light won't light
Back light does not come on.
JBL Flip won't turn on
this doesnt help. how can i get back on?
Jan 11, 2013 | Harman Kardon JBL Flip black
Alright I'm a semi tech guy when it comes to cars
The switch on the steering wheel and/or the relay on the high beams is faulty
Dec 05, 2012 | Cars & Trucks
The lights won't work properly
sounds like contacst in light switch are bad. replace light switch
Nov 26, 2012 | Yamaha Pz480 Phazer Pz 480 Electric Start...
1993 buick park avenue heater won,t work.checked all fuses an relays
i beleive you did more than that.? you,ll probably find all have a common earth , chech and remove it , clean with a wire brush and replace, also chance the fuse you removed and replacer reguardless of it,s appearence , ensure its put back in the correct location,peter.
Sep 03, 2012 | 1993 Buick Park Avenue
My clean filter light won't go off on my frigidaire & my dryer won't turn on
Did you try to remove the back cover after unplugiging your dryer ,to find a lot of lint in the back of the dryer? Some times you may have to clean in this area for fire safety. Maybe this would sold your problem.
Jul 20, 2012 | Frigidaire GLEQ2152ES Electric Dryer
My brake lights stay on until I begin to press the brakes my car. When I press the brakes on my car, the brake light won't turn on and won't turn back on. Does this mean I need to replace my brake...
on your brake pedal yuo have a switch to turn off the brake lights when not in use and when depressed turns on yuor brake lights. i would suggest either trying to adjust them on the pedal and if not replace the switch.
Sep 30, 2011 | 2006 Pontiac G6
How do I change the pilot light as it is not working anymore.
It won't be the pilot light, It will be the gas valve control, if the pilot light actually lights but the burners won't light,, then you need to check the thermocouple , its that little round thing that sits inside the flame of the pilot light, and has (usually) a copper tube that runs back to the actual gas valve, If its gone bad, the signal to the gas valve is lost so the gas never gets released so nothing lights
Jul 07, 2011 | DeLonghi DEFSGG36-SS Gas Kitchen Range
Kwikset 909  909-15 Satin Nickel Smart Code SmartCode Signature Series Touch Logo
44 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
