Question about Samsung NX2000 20.3-Megapixel Digital Compact System Camera with 20-50mm Lens
Nx2000 no flash
External flash not working
I need to clean underneath bobbing on brother nx2000 model
ever heard of canned air .use some to blow it out .
Oct 02, 2016 | Brother Sewing Machines
Nx2000 keeps nesting bobing tthread needle changed lintcleared
nesting bobbin thread is an indication that the needle thread tension is too loose
adjust that tension up more
Oct 01, 2016 | Brother Sewing Machines
Once i fix and remove the External Canon Flash the built in flash does not work. ie the camra still thinks the external flash is fitted.
slide in the external flash in the spring block there 'a micro imterruttore that remains closed, the clip just push up real (with the help you tweezers) and the Micro will open' no longer reports' the external flash
Sep 01, 2011 | Canon EOS 550D Rebel T2i Digital Camera
My camera don't want to make photos with the flash. I activate it from menu, i opened it manually and the picture is without flash. Why?
The camera does not flash. Solution
sp.gif sp.gif Follow this procedure to troubleshoot the camera not flashing.
  1. Select the correct flash mode . NOTE: When set to the Forced Flash setting, the camera should flash for all still pictures.
  2. Perform a reset procedure .
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Region
sp.gif sp.gif Canada United States Products
sp.gif sp.gif DSCF828 Last Modified Date: 03-04-2010sp.gifID: C322716 document.write(""); ---
How to troubleshoot an external flash that will not work. Solution
sp.gif sp.gif IMPORTANT: Depending on the mode of the camera, the external flash may not be available. Refer to the instruction manual of the camera for more information.
  1. Ensure the external flash is properly inserted into the accessory shoe on the camera.
  2. If using the connection cord, ensure it is properly attached.
  3. If the external flash uses batteries, ensure fresh batteries are installed.
  4. Ensure that the POWER switch on the external flash is set to ON .
  5. Ensure the hot shoe setting on the camera is properly set for the type of external flash and camera being used. NOTES:
    • When using a commercially available standard external flash, ensure the hot shoe is turned on.
    • If a Sony external flash is being used with an advanced hot shoe on a Sony camera, ensure the hot shoe is turned off.
    • It may be necessary to refer to the instruction manual of the camera and external flash for specific information about the hot shoe.
  6. Ensure the READY lamp on the external flash is illuminated.
Region
sp.gif sp.gif Canada Latin America United States Products
sp.gif sp.gif Cybershot Digital Still Camera Mavica Last Modified Date: 03-04-2010sp.gifID: C292057 document.write("");
Jul 23, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
Is there a diagram to show the location of the starter for 1992 Nissan NX2000? How could we troubleshoot it?
the starter should be right next the oild pan on the left hand side. and if not then it will be on the lower part of the motor in the front.
Jun 12, 2009 | 1993 Nissan NX
Internal flash not working because of non compatible flash installed
Solution:
Look at the external flash socket.
With the camera in "normal position", i.e., poiting away from you, you shoul see a very small (I realy mean very small) piece of plastic under the rigth inside of the flash shoe... it is the "external flash sensor". It probably is stuck. Work with the point of a knife to try and release it.
In more detail, if you look carefully at the external flash shoe, the are two metal pieces that will help create some pressure. So the flash holder (shoe) is made of two parts: a very rigid one and the metal blades that create the pressure. Look under the blade located nearest to the shuter button.
If you can locate the plastic piece (black in my camera, but can be white) try to have unstuck.
Worked with my camera.
regards
Mig
May 24, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
External flash problems
Sounds like the external flash is being triggered by the pre-flash.
On the D40 set the flash mode to manual. On the F65 set the flash mode to Standard TTL.
Nov 28, 2007 | Nikon F65 35mm SLR Camera
Samsung NX2000 20.3-Megapixel Digital Compact System Camera with 20-50mm Lens Logo
41 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
