Question about Brookstone Video Spy Pen 4 GB,USB Camcorder Recorder Camera 640x480p
Recording light not coming on after reset
After charging the video pen I press the button to start recording to light came on. I then reset the pen but the light is still not coming on .
How do you make recordings on your motorola L6 (record things)
Hello there,
To make recordings on your phone is quite simple. All you need to do is to go to the phones menu, select multimedia, then in the multimedia list you will see recording, then you select it, you can either make video recording or audio recording.
When you are ready just select the record button.
Shortcut to recording a vidoe, just open the camera from the menu, then you select option and select video recording, it will bring out the record option and from there you can record the video you are willing to make.
'''''Thank you for using fixya
Caseytech
Jul 06, 2011 | Motorola Mobility L6 Cellular Phone
I carnt find the button to start recording
  1. set it to "A" position
  2. then when your right hand is holding the camera correctly reach up with your thumb, and press the button.
  3. it looks like a power/charge button
Apr 16, 2009 | JVC GR-D290 Mini DV Digital Camcorder
My flip video camera froze.it wont turn on....
Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
Jan 19, 2009 | Pure Digital Flip Video Ultra Camcorder
Have dcr-pc109, the recording started to be red tinted, somewhat blurred
try using different recording media or press the reset button.normally it's the recording media though.
Jan 05, 2009 | Sony Handycam DCR-PC109 Mini DV Digital...
Can't turn on my camera!
Hi..
I have a link and some information I found on the video option to your camera. This link is for the manual located on hp.com:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=371583&lang=en&cc=us&lc=en&dlc=en&
The following is how to stop video:
To stop recording video, press and release the Video
button again; otherwise, the video will continue recording
until the camera runs out of memory.
NOTE
If you have set the camera to Self-Timer or Self-Timer -
2 Shots (see Using the Self-Timer Settings on page 44),
the camera will start recording 10 seconds after you press
the Video button. However, with the Self-Timer - 2 Shots
setting, the camera only records one video clip.
After recording has stopped, the first frame of the video clip
appears on the Image Display. While it is processing, you can
delete the video clip by pressing the Menu/OK button
Good luck and please let me know if there is anything else i can hep you with--feedback would be geat.. thanks, d
Feb 27, 2008 | HP Photosmart R707 Digital Camera
How do I pause while recording?
As far as I can tell, and yes the documentation is skimpy, when you press the 'record/play' button the video recording pauses. Make sure you press the video icon button, not the 'record/play' button to get it started again. If you press the 'record/play' button, it goes into a 'play back' mode.
Hope this helps...
Dec 26, 2007 | Jazz DV-179 Digital Camera
Record dvd
1. Make sure the dv-camcorder is properly connected
2. Press INPUT repeatedly to select the external
input to record from.
• AV1: Audio/Video Input mounted on back
panel.
• AV2: Audio/Video Input mounted on front
panel.
3. Load a recordable disc.
4. Set a recording mode as necessary by pressing
REC MODE repeatedly.
DVD: XP, SP, LP or EP.
5. Press the REC button once to start recording.
The REC indicator lights in the display window.
6. Press STOP (x) to stop recording.
Nov 14, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Canon ZR300 record button no longer works
hi sir just two things to do first 1- restore to factory setings from the menu and check if it is solved 2- if not just try to see does the knub is in its reguler state if yes so you need to replace it
May 07, 2007 | Canon ZR300 Mini DV Digital Camcorder
My camera - frozen?
Charging the batteries was the first move. Charge for at least 14 hours, and never shoot on low batteries. If the battery gives out while you are recording to memory, it can corrupt the storage media. The lens should work normally with a fully charged battery.
Nov 23, 2006 | Nikon Coolpix 4600 Digital Camera
Brookstone Video Spy Pen 4 GB,USB Camcorder Recorder Camera 640x480p Logo
Top Brookstone Video Cameras Experts
Are you a Brookstone Video Camera Expert? Answer questions, earn points and help others
