Question about Magix Video Pro X
Error code -45 - Magix Video Pro X
Epson printer error codes
code 45 is lost connection:
so plug the USB cable to another USB-port on the printer and restart it with unplugging the electric cable behind. plug it in again and put the printer to "on"
- most probably then it will see the computer again
Code 45 Currently this hardware device is not connected to the computer epson-printer-error-codes-wutfveiel3ypko01ydor435x-4-0.jpg
Sep 05, 2014 | Epson Stylus Office Equipment & Supplies
Stuck on incline error code 45
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Feb 16, 2014 | Precor Exercise & Fitness
Dish network error 31 12 45
I use Dish and have had no signal at all. The error codes are Tuner 2 31-12-45 and tuner 1 11-12-45
Oct 28, 2013 | DISH Network Televison & Video
Error 45 on opening e mail, solution
Problem loading message: Error Code 45If you received an error code 45 when attempting to load a message, you'll need to contact us to resolve this error.
To contact Yahoo about receiving an error code 45 message:
  1. Select Contact Customer Care on this page to go to the help form.
  2. In the form, select:
    1. Your version of Yahoo Mail
    2. Category: Notices and errors
    3. Sub-category: Received temporary error code
  3. Provide these details for at least one message that produced this error:
    • Contact name and email address
    • Date message was received
    • Message subject line
    • The folder containing the email (Inbox, Spam, etc.)
    • How you attempted to open the message when the error displayed (from a folder, from email search results, etc.)
Sep 05, 2013 | Yahoo Mail
Asus maximus iv gene z error code 45
A Windows Error code 45 will display or populate a error message that looks similar to the following:
Currently, this hardware device is not connected to the computer. (Code 45)
The device is not present or was previously attached to the computer. If Device Manager is started with the environment variable DEVMGR_SHOW_NONPRESENT_DEVICES set to 1 (which means show these devices), any previously attached (NONPRESENT) devices are displayed in the device list and assigned this error code.
What is the solution for this then?
To fix this problem, reconnect this hardware device to the computer.
No other resolution is necessary.
Visit also asus, and look for any driver updates for the mainboard:
http://www.service.asus.com/#!downloads/c1wax
Good luck
Jan 24, 2013 | Computers & Internet
Sharp mx 4100n error code L4-45
P, * , CA , P then enter sim # 14 to reset code.
Jan 08, 2013 | Sharp Office Equipment & Supplies
Getting an error code E 45
Error 45 in your camera clearly indicates it is related to a lens issue. Something has caused the lens to jam or stop working. When it does you get the E45 error you have to update the firmware and the error should go away.
Thank you !!
May 23, 2010 | Kodak EasyShare CX7430 Digital Camera
Error code 45 on kodak v570 camera
Error Code #45 happens for me sometimes.
I just turn camera off and then turn it on again.
Usually works for me.
Jul 09, 2009 | Kodak EasyShare V570 Digital Camera
Error code F2-45
Ihave Sharp AR-C160. WHAT DOES THIS H4-01 ERRO CODE MEAN? How do I clear it?
Jul 18, 2008 | Sharp AR-C160 Color Copier
Computers & Internet Logo
192 people viewed this question
Top Magix Computers & Internet Experts
Jax Planet
Jax Planet
Are you a Magix Computer and Internet Expert? Answer questions, earn points and help others
