Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
I toke the red on off switch is pcs.how i could rebuildet back ,no broking pcs,just i need help to assemble the switch,
  • 41 Answers
In fact the red button switch has a locking system in the cover,just force it a bit if it enters and lock again, thank god otherwise you need to change the whole pressure switch
Posted on Sep 28, 2009
How do I wire a light assembly,,,,my ex girlfriend toke it apart when she left...I have everything.need color codes.
See the link below and then enter the model number of your fan in the box. You should be able to retrieve the information you need from there:
http://www.hunterfan.com/Support/Technical-Support/Parts-Manuals
Jul 17, 2015 | Hunter Dryers
Need help putting seat back on, finding fuel switch & kill switch
The only kill switches on the xb9s is the kickstand switch, the right hand thumb switch and the key switch. As for your seat, make sure your tool kit is out of the way(if you still have it) and that the battery is the correct size and is sitting in it's cradle completely. The front of the seat is pushed down dirst and slid forward and the back is popped down onto the two legs.
May 03, 2013 | 2003 Buell Lightning XB9S
Why does the light / safety switch stay on when the door latches shut ?
Most likely there is a part missing from the door latch mechanism that you need. This probably broke off when the handle failed. It would be a tab or wedge shaped piece of plastic that strikes the door switch and pushes the switch closed when the door is completely shut. You will need to find that piece and glue it back on or get a new handle assembly from Samsung.
Aug 01, 2012 | Samsung Microwave Ovens
Once My HardDrive Fell Of The Bed And It Was Working ,Then When I Blugeded It Back It Didn't Work I Toke It To An Expert He said That My HardDesk Is Broke And Needs A Piece That Called 'WD10EAVS 1...
It seem the hard drive broke when you dropped it. If the correct part has been ordered then fit it! I have done this many times using second hand disks and empty hard drive boxes.
Having done this ask again if stuck.
Sep 03, 2017 | Western Digital WD10EAVS 1 TB SATA Hard...
My sister has a mitsubishi expo 1993 and the time belt got destroy my nephew toke it a part and now we don't know how to put it back can you tell me how thanks
you may have damaged your valves when the belt broke.
You will need to find ou the timing marks for the cam gear or gears as well as the timing mark for the crankshaft because if they are not lined up properly it will not start and if it does you could do damage to your valves if they arent already damaged
Jun 09, 2010 | 1992 Mitsubishi Expo
PCS 127 does not heat up. Fan and preheat start.
We were able to unscrew the plate that sits behind the latch. 6 screws I believe. Look towards the middle back-right side you will see a red switch. Click it twice. Before we put plate back we tested oven and it worked!!! Hope this info will help you. Dacor oven has been a real problem and I'm a kitchen designer. Will never recommend Dacor anything to my clients after many oven issues.
Jan 25, 2010 | Dacor Ovens
I broke the red on off switch,craftsman 7 gal 1 hp
use a brass bar.if u can drill a couple hole and use bolts or you could clampi t otll work fine
Jun 15, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Auto Gear does not change smoothly
I think he's referring to the valve body which is the hydraulic part of the gearbox assembly. Can only replace it.
Dec 22, 2008 | 1998 Audi A4
Goodman code 3
if you touch your hot surface ignitor, the oil on your hands will shorten the life of the ignitor. If you not making connections, try lightly pulling terminals out further and clean contacts with a eraser
Nov 13, 2008 | Goodman GMS90703BXA Heater
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
99 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
