Question about Polar FT4 Watch
No power changed the battery now it won't turn on
    New Friend:
Have you tried reversing the battery. Did you try the old battery to see if that is still working. Also make sure you have the right battery?
Posted on May 20, 2014
Won`t start after battery change
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs....
Oct 06, 2015 | Tissot watch - T17.1.586.52 PRC 200...
Watch won't work after changing battery
Apr 20, 2013 | Watches
Might have water damage but power is off and won't turn on
Can u change the battery and see if that was the issue? If so and its not the battery you could open the watch on visibly check for black/scourched marks that would indicate that (probably the water) something has shorted said part(s) with the marks. If you see nothing strange then its time to use a meter to test parts.
Mar 31, 2013 | Watches
Won't run, it it battery operated?
yes it is battery operated,sudjest you get the battery changed at local jewelers.
Jan 09, 2013 | Fossil JR9413 Watch for Men
Stop screen flashing on nike trax fury
Nike Triax Fury 100 Super
Yes you need to replace the battery. I had the same problem. Replaced the battery on mine and everything is fine now.
Nov 29, 2011 | Nike Triax Watches
It appears that the battery died and when I replaced it, the screen still won't turn on.
after replacing the battery you had to reset it. short the pads inside your watch or push all the buttons of your watch at the same time
Jul 08, 2011 | Watches
Just change the battery on my Nike Anvil WC0020 watch and the alarm won't sound for the timer as well as the two alarm settings.
If you changed battery yourself, you've lost the tiny spring without noticing it. Carefully check around the place where you changed the battery. The spring itself is very, very tiny, so, be as concentrated as much as you can. That spring (coilspring named by watchmakers) transmits the signal from watch movement to the watch back cover where the sound membrane is located. In case if you find it, open the watch and insert that spring with the bent out end first in to the desired hole in watch movement (should be named COIL SPRING). After that re-assemble watch and the sound should work.
Jun 02, 2011 | Nike Mettle Anvil Super Watch Obsidian...
Screen goes blank and it says chg in small letters on the right lower side
Actually, "chg" means "change" in this case. Since this is a solar watch, it is not necessary to change the battery. I let my watch sit in the dark for a few months and I came back to the same screen when I dug it out of a drawer. Simply allow the solar cells to get some light to recharge. I left the watch under a lamp overnight because I needed a stopwatch in the morning, and it was charged by the time I woke up. Also, this watch has a power saver function you can turn on and off. If the watch is left in the dark for about an hour, the screen will turn off but the normal functions will continue in order to save power..
Apr 09, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
I changed the batteries and the display will not turn on. The printer seems to have power. I have tried all buttons but no display.
there may be an AC terminal that you will have to contact with the positive side of the battery, also make sure that the batteries were replaced in the same position the old batteries came out
Oct 21, 2009 | Seiko S149 Stopwatch/Printer
Polar FT4 Watch Logo
187 people viewed this question
Top Polar Watches Experts
Jerry Greenberg
Jerry Greenberg
NOEL
NOEL
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
