Question about Radio Communications
HK250 microphone problems
HK250 microphone doesn't work
Can't make calls
Voice Commands are dependent on your connected phone and how you press the button. HK250 Settings
Mark
Motorola Support
Jan 05, 2015 | Motorola Mobility HK250 Universal...
Brand new HK250 bluetooth, been plugged in since 12:30 & it's still not charged. How long does it take to charge up?
no , bluetooth headsets are usually simple to pair , read your manual on how to pair with your device
Mar 23, 2014 | Motorola Mobility HK250 Universal...
Philips SHG7980 microphone problem
Go to Tools...Options...Audio Settings and try choosing different choices for Microphone.
Jan 18, 2014 | Philips PC GAMING HEADSET BLACK/RED...
Mettre mon motorola hk250 en francais
Hello
I have a Motorola HK250, I find several languages except French, ars there a way to add French as an option? thank you
Dec 29, 2013 | Motorola Mobility HK250 Universal...
My Motorola HK250 wont charge is flashing red all the time
Mine is too. Mine will sit solid red for a little then turn solid blue. Then after that it will flash red all the time. I've had it on the charger for the last 2 days and that's all its been doing. I read the flashing red light means the battery is either unchangeable or not making proper contact.
Oct 22, 2013 | Motorola Mobility HK250 Universal...
How do I change language with motorola hk250 headset from italian to english
Turn off the headset. Then hold down the call button and turn the headset on again. The voice interface will ask if you want to continue in a number of different languages. When they ask if you want to continue in the language you want, press the call button again to select that language.
Jan 06, 2013 | Motorola Mobility HK250 Universal...
My microphone used to work,now it doesn't.
Check the PC with an external microphone and if this works then the internal mic can be faulty and should be replaced.
Also open the audio settings and check the level of the microphone settings .
you can test and confirm the working of the microphone.
Aug 09, 2011 | Fujitsu LifeBook A1110 Notebook
I have hp pavilion dv1000 computer. i was using skype v3 for two years with no problem. then i installed skype v5.3. Since then my microphone doesn't work. It looks like some setting got changed. I...
I think you are right.
Try changing your audio-settings, until your mic works again.
I've you still need help, i can remotely control your computer to fix this problem
Good luck,
DJ Skywalker
Jun 19, 2011 | HP Pavilion dv1000 Notebook
Radio Communications Logo
23 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
