Question about Coby 8GB MID7065-8 7" Android 4.0 Tablet
Mid7065 battery problem easily lowbat
How can i prevent it from being easily lowbat?
Cant connect!!!
try to update firmware, keep reset button for several seconds
Dec 17, 2013 | Coby Tablets & eReaders
My asus tablet wont turn on
The battery connector in the Nexus 7 (2012 model) is notoriously problematic. Sometimes dropping the device can cause issues that prevent the Nexus 7 from charging altogether. A hard reset may not work. Fortunately, it is quite easy to fix.
However this will void your warranty.
Pop the back of the Nexus 7 case open by pushing a credit card or guitar pick or small screwdriver under the edge of the black plastic case. Start from the top and gently pry the case open, working your way around. The back of the case will come off quite easily. The battery occupies the bulk of the left-hand side of the unit, and a group of six wires come out of the top of the battery to a connector on the circuit board. Gently push the plug out of the socket connector, wait 15 seconds, and push it back in. Snap the case back on and plug in your charger. You should now see the battery charge image appear.34689589-4d42-4ff6-a950-042de234083f.png
Nov 04, 2013 | ASUS Tablets & eReaders
Google nexus 7 will not power up
Press and hold Volume Down, and then press and hold Power simultaneously until the device turns on.
Hope that helps!
Sep 09, 2013 | Google Nexus 7
My Nexus asus will not turn on even though it be charged over night Had it since Nov 25 2012
You could try to do a hard reset. Press and hold the power button and the volume up button simultaneously for 10-30 seconds and see if the device will then turn on.
Hope that helps!
Aug 05, 2013 | Universal Google Nexus7 7"" Capacitive...
I forgot the password of my tab ang I can't open the tab anymore. How to reset it to factory default so that the password will be resetted as well
I hope this will solve your problem. To reset your tablet go into the settings there should be a privacy section, tap that and then there are options of backup accounts if that is checked you should have no problem getting your password back. Also in that same section should be Factory Data Reset. Tap that and your device will automatically reset.
Jul 31, 2013 | Coby 8GB MID7065-8 7" Android 4.0 Tablet
My nexus 7 will not turn on
You can try a hard reset. Hold down the power button and the volume buttons at the same time. The device should then power on and you can follow the on-screen prompts.
Hope that helps!
Mar 18, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
My nexus 7 is not turning on anymore. It's been charging for days. Any ideas?
However this will void your warranty. Pop the back of the Nexus 7 case open by pushing a credit card or guitar pick or small screwdriver under the edge of the black plastic case. Start from the top and gently pry the case open, working your way around. The back of the case will come off quite easily. The battery occupies the bulk of the left-hand side of the unit, and a group of six wires come out of the top of the battery to a connector on the circuit board. Gently push the plug out of the socket connector, wait 15 seconds, and push it back in. Snap the case back on and plug in your charger. You should now see the battery charge image appear.
Mar 06, 2013 | Tablets & eReaders
Nexus 7 will not completely turn on
Pop the back of the Nexus 7 case open by pushing a credit card or guitar pick or small screwdriver under the edge of the black plastic case. Start from the top and gently pry the case open, working your way around. The back of the case will come off quite easily. The battery occupies the bulk of the left-hand side of the unit, and a group of six wires come out of the top of the battery to a connector on the circuit board. Gently push the plug out of the socket connector, wait 15 seconds, and push it back in. Snap the case back on and plug in your charger. You should now see the battery charge image appear.17d253bb-4ba9-4ee2-99ca-91507603cc78.png
Dec 05, 2012 | ASUS Google Nexus 7 Tablet
Coby 8GB MID7065-8 7" Android 4.0 Tablet Logo
22 people viewed this question
Top Coby Tablets & eReaders Experts
Fred Block
Fred Block
Martin Murray
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
