Question about Geemarc Amplipower 60 Plus Amplified Telephone
Phone will not ring when someone calls
Phone does not ring when someone calls---what do i do
Panasonic KX-T7630 not ringing when someone calls
Look for setting that controls the ring.
Jun 15, 2017 | Panasonic Lands Phones
How do I make one extension on my Norstar M7324 phone system ring?
Hi J,
Do you mean how to make it ring when someone calls a specific phone number, or when someone calls the specific extension?
If for a phone number, then you need the line to appear and ring on the phone. Let me know which one you're doing.
May 14, 2014 | NorStar M7324 Telephone
Incoming calls
Who is your carrier? the voice mail is set up via them call or web site. Your phone rings or not rings check ringer volume and ring tone and check if you always have a good signal.
Mar 07, 2014 | everbuying Cheap Unlocked Phone 5.0 inch...
Our incoming calls are not ringing?
wen i receive incoming calls there is no ring or message alert
Dec 10, 2009 | Uniden Cordless Phone
When someone texts or calls me my phone vibrates instead of ring
You probably have silent mode on. Try pressing and holding the pound or the star key. One of those will probably release silent mode, so that whatever ring setting you have can be used.
Nov 09, 2009 | LG RUMOR Cellular Phone
My Nortel Meridian M2008 phone will not ring
it may be turned down to low.press the program key and use the scroll bar below the keypad to find your option...hopes this helps
Dec 05, 2008 | Nortel Meridian M26 Corded Phone
Only rings one time
when someone calls, the phone rings only one time. calling other people works normally. Is this due to a lack of sufficient current to activate the bells of the three telephones we have in the house?
Jun 10, 2008 | Panasonic KX-TG5632 Phone
Adjust ringer length Nokia 7250
Hi the only way you can make the phone ring longer is to goto settings scroll down to call select call then select call divert then select cancel all diverts after you have dont this then select divert if busy turn this on then divert if out of reach turn this on the select divert if not available now leave them like that then when your phone is switched on it wont goto answer unless your on phone to someone else or you hang up on someone.
With the settings like that it will goto answer phone if phone is off or if you have no signal or if you are on phone to someone else but now your phone will ring for aslong as someone rings you for.
Let me know if you need further assistance
Jan 15, 2008 | Nokia 7250i
Geemarc Amplipower 60 Plus Amplified Telephone Logo
20 people viewed this question
Top Geemarc Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Geemarc Radio Communication Expert? Answer questions, earn points and help others
