Question about WeatherWorks CH-9350 Slow Cooker
Broken crockery interior pot is cracked
Pot is cracked
I have a red model with a white ceramic looking pot. Fine black lines that look like cracks in the crockery have developed and I'm wondering if this makes it unsafe to use.
Does it leak when you fill it with water?
If NOT you can use it.
If so: too bad the cracks are caused by pouring COLD liquids when your pot was HOT!
Dec 18, 2017 | Crock Pots & Slow Cookers
Can you use crock pot liners in a pressure cooker
hi Carol.
this is all i could find out.
Can you use a slow cooker liner that Reynolds offer for the 6Quart pressure cookers? I'm not sure since the lid is a twist on/off. I successfully put a Reynolds Slow Cooker Liner in the instant pot and use the slow cook function. The liner seems to work equally well as it does in my slow cooker.
Amazon.com: Customer Questions & Answers
https://www.amazon.com/ask/questions/Tx2QMG4RH5VUT9U?_encoding=UTF8...
Can you use the liner of a crockpot in the oven?All Crock-Pot® Slow Cooker removable crockery inserts (without lid) may be used safely in the microwave and the oven set up to 400°F. If you own another slow cookerbrand, please refer to your owner's manual for specific crockery cooking medium tolerances.Oven & Microwave Safety - Crock-Pot®www.crock-pot.com/...how-to-use/.../help-and-how-to-use-oven-and-microwave-safety-...Search for: Can you use the liner of a crockpot in the oven?
or go to this link.
Can you use crock pot liners in pressure cooker Google Search
Nov 29, 2017 | Crock Pots & Slow Cookers
Where can I buy a replacement crockery insert for a Hamilton Beach 33966 6-Quart Slow Cooker? I'd like to avoid buying a new unit, if possible.
Believe or not, go to your local Goodwill Store! They have tons of crocks and the lids and the cookers separate frm each other that have been donated becase one of the pieces was broken and they donated the rest of the pieces. Lids and crocks typically range from $1.99 to $5.99 and you benefit your community at the same time.
Sep 02, 2010 | Hamilton Beach 33966 6-Quart Slow Cooker
Insert of a slow cooker over a gas flame
Stoneware by it's nature isn't designed for use over an open flame, as the flame can cause concentrated "hot spots" which could damage (crack) the crockery insert.
I've used mine to reheat mac & cheese I've made using the crock pot, but then again, my Hamiliton Beach crock pot stated the insert was oven safe to 475 degrees.
As far as using in an oven, most crock pot inserts can withstand oven temperatures, but refer to the owner's manual and instructions that came with your particular appliance to see what they reccomend in that regard.
Hope you find this Very Helpful and best regards!
Aug 27, 2009 | Rival 38601 Smart Pot 6-Quart
The crock insert of the KSC700 keeps cracking. The second insert I received cracked in the first 2 minutes of its use. I love the cooker but I don't want it if the crockery cracks every time.
I would suggest calling Kitchenaid Customer Service. This may be an indication that the heating element is simply getting too hot, causing the ceramic insert to fracture.
I would suggest calling Kitchenaid Customer Service. They may replace the entire appliance for you under the 1 Year manufacturer's warranty.
Their toll free phone number is 1-800-541-6390.
Apr 30, 2009 | KitchenAid KSC700 7-Quart Slow Cooker
Cracked ceramic liner on a 84356 WB Crockery cooker
Go to this site http://www.crock-pot.com/CustomerService.aspx?id=rpt and put in your model number (located on the bottom of the unit) and you can order the liner and other parts for your crock pot. The cost is $15.00 plus shipping and applicable tax.
Jan 24, 2009 | Crock Pots & Slow Cookers
Westbend 6 qt crock white round pot
Try the Westbend website or replacements.com. If those two fail, try eBay.
Please remember to rate my solutions! Thanks
Nov 06, 2008 | West Bend 84323 Slow Cooker
WeatherWorks CH-9350 Slow Cooker Logo
53 people viewed this question
Top WeatherWorks Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a WeatherWorks Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
