Question about Sylvania SRT2232S 32" TV
PROGRAM ARMSTRONG CABLE REMOTE TO TV. The power button is broke on tv
SOURCE: TV not working with remote from Cox cable/Scientific Atlanta
Try the code 052.
Posted on May 18, 2007
SOURCE: codes for sylvania tv
have a 2007 Sylvania 15" (LC155SC8). Misplaced my remote. Had to buy 'LOGITECH' by Harmony.
Cost ( $100.00) programs online to the device you have. BEST BUY ($99.00) RADIO SHACK has them, too.
Good luck
Posted on Mar 06, 2009
SOURCE: codes to program tv to direct tv remote
try this
http://2getdtv.com/directv/remote_codes.html
Posted on Apr 06, 2009
  • 10865 Answers
SOURCE: cant program our slvainia t.v with satelite dish remote
Your problem is common because there are so many products on the market these days.
That said, you can purchase one truly universal remote that will absolutely control all of your devices. Go to any TV/electronics store, even a radio shack and take a look at these. Don't be surprised by their price tags, as they are usually in the $100. range.
Posted on Jun 06, 2009
macgroovy2
  • 52 Answers
SOURCE: Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Posted on Jun 18, 2009
If power button is broke on tv, can you still program a universal remote to the tv?
I should think so. Just do the programming to the remote and then turn the tv on and off.
Apr 15, 2012 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
I just purchased a universal remote and programmed it to my Apex and I can't get the cable to work I can't get it to go off mono what do I do?
Make sure your TV is set to Cable (Manually), Then with you TV on, hold the cable button down, and keep pressing the power button, till the TV shuts off...this should set your remote to cable mode! When you turn back on, press cable button then power!
You may have to repeat the steps, for the TV to come back on, to re-program your remote!
Hope this Helps!
Sep 10, 2011 | Apex Digital PF2725 27" TV
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
To perform Auto Program again
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I have a viore tv dvd combo need codes for it
You probably have the same problem that I found after I'd purchased my Viore TV (LC 26VF59), your cable box remote or dish network remote doesn't have the Viore codes built in. Bummer. I looked around and couldn't find codes for my Viore. Doubt you'll find them for yours. Here's a helpful suggestion I read about that works for me:
I bought for $20.00 a Sony RM-VL600 Easy Learn remote control from my electronics store. It's EZ because you only have to place the Sony head to head with the Viore remote, press TV setup and follow Sony's instructions to have its remote catch and learn the codes from your Viore remote. I only programmed my Sony for the Power On/Off, Vol Up/Down from my Viore remote. You back out of Setup and now your Sony will control the TV for those functions. Next you get your cable box or satellite remote put it head to head with the Sony remote, press the CABLE or SATELLITE set-up button on the Sony and then have it learn all the C or S functions you want from that remote. You do program in this mode the Power On/Off button, but you don't program the Vol Up/Down. The volume for the TV will work when you're all finished and operating under the Cable or Satellite button on the Sony remote.
Now, you press the TV button on the Sony and then the Power button. The TV turns on. Now you press the Cable or Sat button and then the Power button and the Cable or Sat box turns on. Like I said, even though now you are operating the Sony remote under the Cable or Sat button the TV volume instructions carry over to this side of the remote so you don't have to switch back to the TV button to raise or lower volume of the TV.
When I'm done watching, I hit the Power off and the cable box turns off. I then hit the TV button and again the Power off button and the TV turns off. So, it's a little inconvenient when starting and stopping, but at least you are using only one remote.
Hope this has helped.
Nov 19, 2010 | One For All URC-3021 Remote Control
Remote control for Armstrong minisplit
You may be able to get any make of remote universal remote control and program it to operate your systems.
Mar 01, 2010 | RCA Universal Remote Control
Will not turn on with remot and turn on button is
Is there a way you can power it on, by pressing hard on the button? The get a new Universal remote and program the TV.
Otherwise, it might be time to get a new TV.
Feb 03, 2010 | Philips Magnavox 20MC4304 20 in....
The cable guy programmed the cable remote to turn on/off the TV. We used it to turn the TV to stand-by. Then pushed the power button on the TV to turn the power off. Haven't been able to turn the TV on...
First use the original remote control that came with your tv, or just manually turn it on at the tv itself to bes sure it is working. If it works you should call the tech support for the cable company to program their remote control to a different code - or put it back to to factory state and just use two remotes.
Sep 12, 2009 | Panasonic TC-32LX50 32 in. HD-Ready LCD...
Program bell expressvu remote for new tv
The easiest way is to do device code scan. Since you want to program the TV, hold the TV button on your bell expressvu remote. When all the top buttons light up, press the power button, the TV button light should remain lit. Keep pressing up/down until your TV turns off. When your TV turns off, press the # button. Thats all. Your done.
If you want to set up the AUX button, hold the AUX button until all the buttons light up. Then press * and either
0 - second TV
1 - second VCR/DVD player
2 - audio amplifier or cable box
Then press the power button and press up/down until the device turns off. The last step is to press # and your done.
Oct 22, 2007 | Televison & Video
Problem with channel changing
You must program the tv. Go into the MENU and find AUTO PROGRAM. Then program it and it should work.
Sep 11, 2007 | Sharp 27K-S100 TV
Sylvania SRT2232S 32" TV Logo
64 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
