Question about Xerox DOCUMATE 510 Flatbed Scanner
After scan says docs not converted
See above statement
The printer is printer error code 3101.It can't scan doc to email
Use the ALTER DATABASE SET SINGLE_USER to remove users from the database.
Or, wait until all users have finished using the database, and then use the RESTORE DATABASE statement. Make sure that you are not using the database being loaded when you issue the RESTORE DATABASE statement. Although not required, it is best to run the RESTORE DATABASE statement from the master database.
For more help visit cbr tech solutions
Sep 05, 2011 | Office Equipment & Supplies
I scanned to pdf but how do I get document to my document file?
A PDF file can be placed in any folder on your computer and opened with a PDF viewer like Adobe Reader. You can convert a PDF to a document (DOC) file but you cannot open a PDF file with a document editor like Microsoft Word. You may want to scan your document as an image file like TIFF or JPG then use the Insert Picture function to get it into a DOC file.
I hope this helps.
Jun 16, 2011 | Office Equipment & Supplies
When I scan a doc It comes up as a jpeg using my new sx425w I wish to convert to a word doc to alter text but I do not get the option wnen scanning.Do I have I he wrong machine.or can you advise how to...
you need to have ocr software to convert the text from a scanned image to readable text. try going to microsoft office website and downloading the software. can also try the scanner manufacturers website for it.
Jan 16, 2011 | Epson Office Equipment & Supplies
Need 2 things: A way to scan a document into Word with a HP PCS-2355 and a Vista OS and, a cheap way to convert a doc. to a .pdf file. Thank you
Get an old PC, install Ubuntu Linux with Open Office.org, export as PDF.
This may even work under Windows with Open Office.org.
Sep 27, 2010 | HP PSC 2355 All-In-One InkJet Printer
When I go to scan a doc to e-mail I get an error message that says (Not Set Up on PC) and I am unable to scan and send a doc via e=mail
Well as a workaround, as long as you can actually scan and save ... What you do is scan what you want, save it, then either save it as a PDF OR convert it to PDF After which you can then "Attach" it to any email you wish. I recommend PDF as most people have Adobe Reader.
If you can't scan to PDF, and it only saves as say JPEG, then get DoPDF http://www.dopdf.com/ To convert it from JPEG, JPG, BMP etc.
Feb 03, 2010 | HP LaserJet 3050 All-In-One Printer
I have a document that has a table in it and within that table I've written an IF statement. This doc is loaded in another software that when executed it will display data based on fields that are inputted...
the option that i can c is try keep the statement in another worksheet in the same workbook and re-frace/re-work ur formula....if can send me the file then i can have a look at that... i have been using various spreadsheets since 1986, begning from lotus123/QuatroPro then XL....
so have fair idea how it may be worked out...
send it to suresh_krishnan1961@yahoo.com
Dec 17, 2009 | Computers & Internet
I am failer to edit scan text in to word why?
because scanned text in jpeg form and word is document form..there must be need converter jpg to doc converter. You can use omnipage .it converts jpg to doc
Jun 30, 2009 | Canon CanoScan LiDE 600F Flatbed Scanner
Email scanned docs
You don't. Scanners save everything as a Picture. Test is not text, it is a combination of thousands of dots that make up a picture. It takes an OCR and very complicated software to read text from a picture.
Feb 17, 2009 | Canon CanoScan 4200F Flatbed Scanner
Problem using OCR with Canon MP610 all-in-one
I got this message too, before I installed an OCR program. It may be that you need to install one (or specify it, if you have one already). With my MP610, an installation disk was included that contained the OmniPage SE program for OCR. When I installed that on my computer, and told MP Navigator (another Canon-supplied program, that controls scanning) to use it as the "Open With" program for OCR, it worked.
Dec 15, 2008 | Canon MP610 Photo All-In-One Printer
Xerox DOCUMATE 510 Flatbed Scanner Logo
23 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
