Question about Texas Instruments TI-84 Plus Calculator
Smart pad i can't exit the app
It says to press 2nd and on i press and nothing happens
How can i install facebook app on my vizio smart tv after its been deleted
Go to the App store and search for it, and then download it again. The is a video tutorial in the main link.
Method 3 Vizio Smart TVs
  1. Verify that your Vizio Smart TV is connected to the Internet using a wireless or wired connection. ...
  2. Power on your television and press the "V" button on your remote. ...
  3. Use the arrow keys on your remote to highlight either the Yahoo TV Store or CTV Store. ...
  4. Press "OK" to launch the app store.
More items...
4 Ways to Add Apps to a Smart TV - wikiHow
www.wikihow.com/Add-Apps-to-a-Smart-TV
facebook app on my vizio smart tv Google Search
Jan 04, 2017 | Vizio Televison & Video
My 32 in.RCA smart tv will not connect to any apps but Netflix. And now when I press the apps button the screen just flashes and nothing happens.
Do a hard reset to this set and check. If it do not help you, contact the authorized service center for RCA. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Feb 02, 2015 | Televison & Video
Faema smart a2 espresso machine i need to reprogram it is there any one can help me out
Assuming you've got a grind which brews out correctly when manually brewed.....
Fill and tamp a portafilter, ready. Press and hold 'stop' pad until machine beeps. Tap the pad you want to program. Lock in the portafilter. Press and hold the pad until you get the volume required. Press 'stop' to exit programming, the machine will stop beeping.
Jun 06, 2014 | Faema Smart A2 Automatic Espresso Machine...
Frozen asus memo pad
the memeory if full wont doload any apps,internal memery
Feb 03, 2014 | ASUS Memo Pad ME172V
How can I get the answers fro the sig fig calculator and the unit converters found in the science tools app out of scientific notation? I want them to show in regular form.
Press MODE. Use the arrows to highlight NORMAL on the top line and press ENTER. Highlight FLOAT on the second line and press ENTER. Press 2ND [QUIT] to exit the mode screen.
Mar 27, 2011 | Texas Instruments TI-84 Plus Calculator
I need license key smart movie 4.15,my phone is nokia n72,my devise 354568010968152
http://www.lonelycatgames.com/?app=shop&code=smartmovie&action=add&platform=Symbian
pls rate:P
Jan 10, 2011 | Nokia Unlock N70 N71 N72 N90 6630 6680...
When graphing the calculator only allows me to graph on function. When typing in a new function the first function that was highlighted became unhighlighted and only the new function is highlighted now.
If you ran the dynamic graphing application called Transfrm you will only see one graph. It takes over the graphing from the native OS.
You will recognize it by the graph style at the left of the Y1=, etc. as in picture
As you can see, only one = is highlighted, meaning only Y1 will be drawn. To recover the native Y= screen, you must unload the Transfrm App from memory.
Here is how to do it.
Exit what you are doing and go to main calculator screen.
Press the Apps button.
Scroll down to find the Transfrm App
Highlight the : before the name and press ENTER.
The screen appears as on the second screen capture above
Press 1:Uninstall
This will unload it from memory and you will be able to draw multiples graphs.
There is the possibility that the failure to draw multiple graph has nothing to do with Transfrm. In that case it is most likely due to the Stat Plots being turned ON. Turn them OFF
Press [2nd][Y=] (STAT PLOT)
Select [4:PlotsOff] and press [ENTER]
Dec 30, 2009 | Texas Instruments TI-84 Plus Silver...
My calculator turnd on, but when I press 1,2,3... nothing happens. I can press apps, math, prgm...and they work. What's wrong?
Need to set your brightness setting . Press 2nd and the up or down arrow key this should darken the curser and the display to where you can see it .
Oct 08, 2009 | Texas Instruments TI-83 Plus Calculator
My TI-86 calculator doesn't have a cursor. I can turn it on and adjust the contrast from dark to light but no cursor appears and nothing comes up when I punch any of the buttons!
Press [EXIT] or [2nd][QUIT] to terminate the program that may be hung in memory. Press [2nd] MEM[F3][F1][F4].
You may have to reset contrast.
1.Press and release [2nd] key.
2. Press and hold [UpArrow] to darken or press and hold [DownArrow] to lighten it.
Hope it helps.
Aug 15, 2009 | Texas Instruments TI-86 Calculator
Texas Instruments TI-84 Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
