Question about Dell Inspiron 518 Desktop Computer
Monitor will turn off after a second
Monitor will turn off after each time turning it on
    Top Expert:
  • Dell Master
  • 8,204 Answers
Dont think its your monitor thats at fault,,but try another one.
does your pc shut down as well?
Posted on Apr 05, 2015
Power flashes on for a second and then turns off completely
The most likely problem is that the power supply has failed.
Jul 19, 2013 | Shuttle XPC SD32G2 Barebone
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
How do you perform a full reset on a kenwood tk-370
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor Key Off = off 1 = Monitor momentary 2 = Monitor Lock 3 = Squelch off momentary 2. Scan Key Off = off Co = carrier operate To = Time operate 3. Dial Key Off = off On = enable 4. TA key TA = talkaround RV = Reverse Off 5. Lo Key On Off 6. Priority None 1 = fixed 2 = selected 7. Fixed Priority Channel Turn selector to channel 8. Look back time A Turn selector to time in seconds 9. Look back time B Turn selector to time in seconds 10. Revert Channel 1 = Selected 2 = Last Call 3 = Last used 4 = Selected + Talkback 5 = Priority 6 = Priority + Talkback 11. Tx Dwell time Turn selector to time in seconds 12. Drop out delay Turn selector to time in seconds 13. Time out timer Turn selector to time in seconds 14. Tot Pre-alert Turn selector to time in seconds 15. Tot Rekey time Turn selector to time in seconds 16. Tot reset time Turn selector to time in seconds 17. Squelch Level Turn selector to Squelch 18. Beep tone On Off 19. Signalling And Or 20. Battery Save On Off 21. Selectable QT On Off 22. Clr to transpond On Off 23. Del/ Add On Off Pressing (Dial) allows programming of: DTMF 24. digit time Turn selector to time in milliseconds 25. inter digit time Turn selector to time in milliseconds 26. First digit time Turn selector to time in milliseconds 27. Rise time Turn selector to time in milliseconds 28. Rise time with QT Turn selector to time in milliseconds 29. PTT ID Off 1 = connect 2 = disconnect 3 = Both 30. Dial ID On Off 31. Connect ID 32. Disconnect ID 33. # of DTMF keys on Keypad 12 16 34. DTMF hold time On Off 35. Store & send On Off 36. D key assignment Turn selector to D or time in seconds for pause 37. Dtmf Signaling Off 1 = code squelch 2 = Selective Call 38. Intermediate Code OFF A B C D E F 39. Group Code OFF A B C D E F 40. Auto Reset time Turn selector for time in Seconds 41. Call Alert/ Transpond Off 1 = 2 = 3 4 5 42. Transpond On Off Pressing (TA) will allow you to program Frequencies Use selector to choose channel Press PTT Enter Rx frequency using: - the Selector Knob to change kHz; - the Selector Knob + (light) to change MHz. If no channel is Shown press the (LO) button. Press PTT Enter Rx CTCSS code Press PTT Enter Tx Frequency as above Press PTT Enter Tx CTCSS code Press PTT 1. Option Signal Off 1 = DTMF 2 = 2-Tone 2. PTT ID On Off 3. Add/ Del 4. Busy Tx 5. Clock frequency shift 6. Power Hi Low Repeat for the other channels (you've got a 32 channel radio, so it may take a while...) <end>
Sep 16, 2010 | Kenwood Radio TK 260 360 270 370 2100 3100...
We leave our computer turned on at night but we turn off the monitor. The last two weeks when we have turned on our monitor in the morning it will show the desktop but when we move the mouse the monitor...
Yes. Do not turn the monitor off by its power switch, let the computer do the work for you. Alot of times when people use the power switch to turn off the monitor, the computer sees that all of a sudden the monitor has been disconnected from the pc. when that happens the pc sees it as a device beimg unplugged and removes that certain device from the pc's list of things that should be connected, and when you turn it back on the pc sees it again and starts loading drivers for that new part(monitor)
Sep 21, 2009 | AOC LM729 17" LCD Monitor
Viewsonic vg900b turns on, and turns off after 1 second
bad board inside do to heat clean your new one more offen. replace monitor.
Sep 08, 2009 | ViewSonic VG900b 19" LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Need manual for kenwood tk-270 transceiver does any one no were i
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor KeyOff = off1 = Monitor momentary2 = Monitor Lock3 = Squelch off momentary 2. Scan KeyOff = offCo = carrier operateTo = Time operate 3. Dial KeyOff = offOn = enable 4. TA keyTA = talkaroundRV = ReverseOff 5. Lo KeyOnOff 6. PriorityNone1 = fixed2 = selected 7. Fixed Priority ChannelTurn selector to channel 8. Look back time ATurn selector to time in seconds 9. Look back time BTurn selector to time in seconds 10. Revert Channel1 = Selected2 = Last Call3 = Last used4 = Selected + Talkback5 = Priority6 = Priority + Talkback 11. Tx Dwell timeTurn selector to time in seconds 12. Drop out delayTurn selector to time in seconds 13. Time out timerTurn selector to time in seconds 14. Tot Pre-alertTurn selector to time in seconds 15. Tot Rekey timeTurn selector to time in seconds 16. Tot reset timeTurn selector to time in seconds
Apr 27, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
LCD show right picture for 1 second when I turn on, then go black
you need to read the monitor manual . other wise you can contract the dealer.
Jan 21, 2009 | Computers & Internet
Monitor show picture for a few seconds, then turns black
It sounds like the power supply board on your monitor is failing. If it's still under warranty you might be able to get a replacement from the manufacturer - if not, you might be able to have it repaired at a computer or TV repair shop.
May 14, 2008 | E-Machines E17T4 LCD Monitor
The picture disapears, though the monitors stays on - every few seconds
Check the cable connections on the back of the monitor and the PC it sounds like the connection isn't made properly make sure they are tight.
Oct 28, 2006 | BenQ FP71E+ (Black, Silver) (Silver,...
Dell Inspiron 518 Desktop Computer   Logo
46 people viewed this question
Alun Cox
