Question about Volfenhag ZX-8400 Car Audio Amplifier
Power to amp but no light happened when my battery went dead replaced
Happened when battery went dead
  • 1,602 Answers
The power amp has a short in the unit and it drain everything out of the battery, that why the battery is dead. it is really possible that a capacitor is open or shorting out cause the unit to drain the battery.
Posted on Apr 23, 2015
I have a 2002 Hyundai Santa Fe, my vehicle went dead no power, I replaced the alternator, checking power, when running, by pulling battery cable, anyhow alternator was dead, worked fine for about a month,...
With the engine running, connect a volt meter to the battery the voltage must be around 14 volts, if not the alternator or regulator is at fault ,if ok connect a amp meter in series with pos. terminal at the battery, with every thing switched off the draw must be less then 1/4 amp. if more check for shorts or lights on in the trunk or glove box.
May 01, 2017 | Cars & Trucks
Battery light flashing
The battery light on, is an indication of alternator failure. If your battery is more than 3 years old it needs replacement . A bad battery can damage a new alternator (full field condition). The age of your truck warrants inspection of the charging system. It requires at Least 20 amps output, from the alternator to run the engine.
May 19, 2017 | 2004 Ford Explorer
I have a 97 Sable and battery light came on and everything started going wacky. Lost all guages, speedometer, RPMs, etc. All lights came on my dash. Then all my lights went out and the car died. I was told...
that's becasue the new abattery went dead because it was not charging. The battery light must be OFF to charge the battery. Take it back to whoever fixed it. May be a bad wire betwen battery & alternator too.
check the 175 amp mega fuse in the engine compartment.
cehck this ground for a good connection - G104
Left front fender near air cleaner
check the 20 amp fuse for the charging system. Fuse 26 in teh engine compartment fuse box.
Aug 16, 2011 | 1997 Mercury Sable
I have a 1986 Chevrolet El Camino V6. Brand new battery. Car is completely dead. Was running great and all of a sudden went dead. NO power at all, no lights or horn. I checked battery connections. What...
IF THE BATTERY IS FULLY CHARGED, 12.60 VOLTS & THE CABLES ARE CLEAN & TIGHT, THERE ARE FUSIBLE LINKS AT THE STARTER THAT SUPPLY POWER TO EVERYTHING IN THE VEHICLE. THEY ARE FASTENED ON THE SAME LARGE TERMINAL AS THE MAIN BATTERY CABLE ON THE STARTER. THE FUSIBLE LINKS ARE SPECIAL WIRES DESIGNED TO BURN INTO IF A SHORT CIRCUIT HAPPENS. THE BIG BLACK THING THERE IS NOT A FUSE, IT IS JUST A CONNECTOR. TO FASTEN THE MAIN WIRE TO THE FUSIBLE LINK WIRE. IF YOU PULL ON THE FUSIBLE LINK IT WILL STRETCH LIKE STIFF RUBBER. IF IT STRETCHES IT WILL NEED TO BE REPAIRED OR REPLACED. IF IT DOESN'T STRETCH IT IS PROBABLY OK & IT MAY BE A BAD CABLE.
Jan 27, 2011 | 1986 Chevrolet El Camino
Cordless phone went dead
leave batt out for a long period of time,then replace
Nov 30, 2009 | Panasonic KX-TG2431 Cordless Phone
Hp zd9500 My I.T. put in a new hard drive the other day and it was running fine. Today I turned it on, it was booting up and then went completely dead - no lights, or anything. The power cord is working -...
You could test to see if hard drive is culprit by removing the drive. This is done by removing the access panel on bottom of laptop and slipping out the drive. Once out, try turning on laptop. It won't boot up, but you should get power light on.
I suspect you will not.
If so, problem is in power supply within laptop. Fixing requires a full diagnostic check of the power supply and battery charger. I highly recommend a trained technician for that.
Oct 05, 2009 | HP Pavilion dv6000z Notebook
2004 Ford Focus battery went dead had to replace,now no power to
found out there is a 10 amp fuse on the back of the radio itself,replaced it and all is well
Sep 17, 2009 | 2004 Ford Focus
94 nissan sentra brake light/ battery light
Your alternator is dead/dying. Nissan puts both of those lights on to tell you that the alternator isn't charging your battery.
Jun 10, 2009 | 1994 Nissan Sentra 4-Door
Dell Wireless Mouse dead
now mouse is open & clean by isoprpile & check battery conector after check now mouse its working.
Aug 25, 2017 | Dell Wireless Keyboard Optical Mouse w0147
Volfenhag ZX-8400 Car Audio Amplifier Logo
127 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
Professor_V
Professor_V
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
