Question about Eagle FishElite 480 Sonar/GPS Mapping Combo GPS Receiver
Fishelite 480 loading detailed maps
Not reading detailed map
Tom Tom instructions is state I can download other maps from around the world at no cost (currently loaded with Australia). How do I down load maps for North America
have you downloaded software to talk to tom tom device and the web site for tom tom
http://au.support.tomtom.com/app/answers/detail/a_id/12493/~/installing-mydrive-connect
don't know if maps are free
http://uk.support.tomtom.com/app/answers/detail/a_id/15230/~/changing-map-on-navigation-device-with-computer
Oct 03, 2016 | Tomtom GO GPS
Does not show depths on lake map anymore
try your zoom button zoom in see if the depth shows up
Oct 12, 2013 | Eagle Fishelite 642c Color Fishfinder Gps...
Hard reset on eagle fish elite
Elite 640C Reset 1. Turn unit OFF 1. Turn unit OFF 2. Press and hold the PAGES key 2. Press and hold the ZIN&ZOUT Keys at the same time 3. Press and hold the PWR key 3. Press and hold the PWR key 4. Release both buttons when the unit powers up to Full Map Screen 4. Release both buttons when the unit powers up to Full Map Screen Soft Reset (Does not delete GPS Data) Hard Reset (Deletes stored GPS Data such as Waypoints and trails)
May 27, 2012 | Eagle Industries FishElite 640C GPS...
I need a free copy of a world map that shows all the world's time zones, preferably in colour (for my students) Thank you Regards, Barry
This is a very large and easy to read map of the world with time zones: Map 1
This map is a lot more detailed but a little bit more difficult to read: Map 2
Hope this helps.
Mar 26, 2011 | Computers & Internet
When I insert the Micro SD into the Garmin, the maps are not being read off of the card. When I try to plot a coarse it states "No Maps" loaded.
  • Press TOOLS
  • Press SETTINGS (or LOCALE on some models that don't have a settings icon)
  • Press MAPS
  • At the bottom of the screen press MAP INFO
Your map names should be shown with a tick beside them. If the maps aren't loaded the tick is probably missing. Press the map name and the tick will appear. The map is now selected and should load.
Nov 27, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
May 28, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Quest: Not able to upload detail maps
hi bud, just had the same problem. hard reset i.e turn off unit, hold down ok, page and then the power button at the same time. it should then ask you if you want to delete all data. select yes and then you should be able to upload your maps again, this worked for me good luck
Feb 18, 2009 | Garmin Quest GPS Receiver
Garmin nuvi says, "no detailed maps found to support routing."
I am very sorry to hear that you are having problems with the unit. You
may need to switch the unit on and press and hold the centre of the
screen until the message ?No detailed maps? message disappears.
If your map detail is missing, then the map information may have been
disabled. To check to see if the mapping has been disabled, follow the
steps below:
From the Where to? and View Map page, touch the Spanner icon, settings
(Tools).
Touch Map.
Touch Map Info.
The unit should display the name of the map that is loaded to the unit.
The box in front of the map name should have a tick in it. If it does
not, touch the box to place a tick in it.
Then please test by searching for an address.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
Screan on 200w garmin reads "no detailed maps found"
Check your menu-maps-map info,
Tich the box
Unit I.D. and serial number needed to activate.
switch off and restart.
Regards.
Jan 04, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Jan 01, 2009 | Garmin nuvi 200W GPS Receiver
GPS Logo
14 people viewed this question
Top Eagle GPS Experts
fordexpert
Computer Links
Are you an Eagle GPS Expert? Answer questions, earn points and help others
