Question about MSI K8MM-V Motherboard
Regarding SATA 300 on VT8237R
Hi, I have been doing a bit of research to replace my failed 40gb SP0411C, the only viable option is the 80gb Seagate 7200.10, still available in the market. I suppose, this drive supports the revised 300mbps spec which is not supported by VT8237. However, most controllers allow forward compatibility (autonegotiation), it seems that this particular southbridge lacks such support (trusted source: wikipedia). However, it hasnt been clearly stated whether jumper settings (150mbps limit) can help overcome this problem. Post this discovery I have searched for some other sources on internet, but have reached ambiguous conclusions, some forums report that even jumper settings were of no help, and others, such as these confirm that jumpers were a success. I am basically clueless and need some confirmation from some expert. Please help.
MB: K8MM V, MANU: MSI.
  • recon_lallu Jun 18, 2009
    Clarification:
    I am not running raid. Its just a single hdd config. I am looking to replace my broken hdd (SP0411C), but the search for sata 150 has been quite some task, no brand new product belonging to this specie is available anymore (used hdds are risky). I wanna replace it with a sata 300 on vt8237r, and wanted a confirmation from those who have been able to do this successfully or otherwise.
  • Hank May 11, 2010
    Are you running raid? How many hard drives do you have?
    Hank
  • 433 Answers
Since you are only running one drive you can do the following:
1) Go to Newegg.com and go to hard drives. Look for the Western Digital WD800JD. This has a jumper that you can set on the hard drive to force it back to sata 150. You can also read customer reviews to learn of other's experiences.
2) Instead of replacing with sata you can go IDE. This is your second option if you are uncomfortable with sata.
Both hard drives are available from Newegg. I've purchased from them many times and I have nothing but positive feelings about the company.
Regards,
Hank
Posted on Jun 18, 2009
Www com 500
there is no need for a driver. for PATA. drive!
If XP then SATA drives does. but yours is not a SATA.
you failed to state what hardware this is, desk top, lap top? what?
a server?"
and what OS, Windoz, , Linux ? and version.
my guess is you have a problem. but failed to state what.
we can diagnose any problems, but must know it.
Oct 01, 2013 | Seagate Barracuda Model ST380011A 80GB IDE...
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Failed segate drive need replacement solution
Yes the ATA-300 is compatible with notebook computers.
I use Hitachi HTS7210 80GB.
Oct 07, 2009 | Seagate (ST9402113A) 40 GB ATA-100 Hard...
Seagate SATA 80GB Master Drive and Seagate IDE 80GB Salve Drive
Dear,
You have to make IDE drive as slave. For this put the jumper to slave in IDE drive. Possibility of CMOS battery is rare, but you can confirm it by checking your system time in BIOS. If system time is ok then there is no problem in CMOS battery and you need not to replace it.
Thanks,
Rakesh Kumar
Jul 23, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
HI i m posting the same problem onceagain with the trouble shooti
You could try flashing to the latest bios and disabling SATA RAID, disabling IDEs including bus master if u dont use any.
Apr 19, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
Hp compaq dc7600sff
750GB Seagate Hard Disk Drive IDE ATA100 7200rpm 16MB
available at http://www.microdirect.co.uk/(17679)750GB-Seagate-Hard-Disk-Drive-IDE-ATA100.aspx
1TB (1000 GB) Seagate Barracuda SATA II 300 32MB cache
also available at http://www.microdirect.co.uk/(23250)1TB-1000-GB-Seagate-Barracuda-SATA-II-300.aspx
Both HDD`s are what i consider to be best in there range and very good value for money
Nov 19, 2007 | Computers & Internet
SATA 80GB Seagate HDD
When your 80GB SATA Seagate HDD complains of bad sectors while booting, this is a sign of a failing hard drive. Today's hard drives will actually self-correct a certain amount of bad sectors before you get any kind of error message. If you are getting "bad sector" errors, this is because the drive has so many problems that it can no longer self-repair. You asked if this may have happened because you have formatted the drive many times. No, bad sectors was not caused by formatting. Your drive did not become "dead slow" because of the formatting. It became slow because your cpu now has to do much more processing to "work around" the bad sectors on the drive. You also asked if you could recover your hard drive to normal state. Please understand that once a drive shows bad sectors, it will not be long before the drive fails completely, at which point you will no longer be able to access anything at all on the drive. No, this drive cannot be recovered. Instead, you should save all the data you can from this drive, and you should do this as soon as possible, before it fails altogether.
Mar 27, 2007 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
MSI K8MM-V Motherboard Logo
245 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
