Question about Water Heaters
F code on rheem prestige furnace
Blower not strong enough
Heater blower won't start and we get o heat! What is going on with this Rheem REAA-080c
Earl, is this a furnace heater for your house? And are you referring to the blower that distributes the heat throughout the house? And does this unit have a flame exhaust blower? This last blower is a small blower in the unit itself, if it has one you usually can spot it.
Dec 08, 2016 | Rheem Water Heaters
I have Rheem Pvw50, 50 gallon water heater installed at home. For the past few days, there is a noise coming out of blower motor. What could be the reason?
Your water heat is at an age that I would recommend replacing the whole unit. That one cannot be too efficient and most likely has sediment built up on the bottom of it pretty bad.
Jan 25, 2016 | Rheem Water Heaters
Rheem gas furnace displayes 3 blinks, does not ignite.....3 blinks means???
Look inside the unit, the codes are usually on or near the schematic of the unit. Otherwise check the owners manual.
Feb 16, 2015 | Rheem Water Heaters
Aircondition builds ice on coil
Either lack of refrigerant, stopped up metering device or capillary tube/s, or lack of air flow (due to bad blower motor, or dirty indoor coil) Good luck.
May 19, 2014 | Rheem Complete Split System Gas Furnace 5...
I have a Rheem Criterion II gas furnace. I have been looking for the filter. Where is It?
If it is @ the furnace, then it is in the blower compartment on the return side.
Dec 07, 2013 | Water Heaters
Furnace tries to start. Blower fan moves momentarily but doesn't.
May have a start capacitor on fan to get it started. If fan only jerks, it is probably bad. Replace if needed. Be sure to short it out with a rubber handled screwdriver or something to make it spark before removing.
Feb 18, 2013 | Rheem Water Heaters
Fuirnace blower motor doesn't blow very hard and sound rough
Maybe if you put a drop of liquid soap on the shaft for the fan. Since it is a heater, I wouldn't use a lubricant like wd-40. GOOD LUCK. Soap is cheap. Hope it works.
Jul 02, 2012 | Rheem Gas Furnaces 125K BTU 80 AFUE Single...
Rheem Tankless wh model rtg-74pvn shuts off error code c4 76
Contact Rheem; the Burner control unit has lost comm with the remote...the part is warranteed for up to five years.
Nov 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Me too
1.Not an expert with natural gas furnaces.
2.Statements below are from my own personal experience, and knowledge from.
The red blinking light you see is on a computer control board. The flashes of the red light represent a type of code. Think of it as a Morse Code, if you will.
For example: Red light blinks three times rapidly, pause, then blinks one more time. This code represents a particular fault. (Fault = Problem)
There is a sticker, with a chart of codes listed for this red light. It is usually placed very near the red light.
A gas furnace should be repaired by a competent HVAC technician. This is not a device that should be attended to, by those who are not trained.
An HVAC technician will know where to look, what parts are needed, and if the gas furnace is safe enough to put back on line. (Safe enough to use)
Sep 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Water Heaters Logo
18 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
