Question about Fender Music
I do not no how to tune my electric guitar
When i was playing my guitar i was tuneing it but i did not no how to so i messed i up and now it sounds wired someone tell me how to tune it up! thanks!!!
    Problem Solver:
  • 18 Answers
You should get a tuner -there are free ones for phones and on the internet. the strings are from thinnist on the bottom E -B -G -D -A -E
http://www.gieson.com/Library/projects/utilities/tuner/
Posted on Jun 27, 2014
SFroese
  • 141 Answers
SOURCE: how can i tune my electric guitar
One way is that the dial-tone on your phone is an F (If you live in North America).
Or, if you are like me, you have perfect pitch! :)
Mostly, you should invest in an electronic tuner, or at least a tuning fork.
Posted on Sep 06, 2008
  • 17 Answers
SOURCE: "G" string tunning problems,
hi there .... flat means does the string go lower in pitch ...needing the string to be tightend after you have bent it ?
Do you give the strings a real good pull a few times after fitting? this often corrects the problem .... let me know ..as there could be a few other reasons
cheers Pete
Posted on Feb 03, 2009
SOURCE: LP epiphone 100 "g" string problem,
well, i have this guitar, for me if i bent the string it would pop off the nut, but it went out of tune on me also becuase of the tuners. so i suggest checking the nut to make sure the string sits completely flush in there, and than also just upgrading your tuners if you can and it will be fine. but deffinately upgrading your tuners would stop that hopefully but still could be something with the nut becuase i had both. tuners = machine heads
Posted on Mar 25, 2009
roadhouse64
SOURCE: Gibson Les Paul wont stay in tune
clean out the slots with the stings use gibson vintage nickle wound 10s smooth notches on bridge dry graphite on nut slots lite oil on metal bridge 3 wraps on tuning posts hold 1st fret pull strings up to stretch and retune,do this a few times always set guitar on a stand to acclimate to, the temp at the gig ,you must spend the time to stretch out the strings. Jim 30 yr guitarist
Posted on Jun 14, 2009
  • 5603 Answers
SOURCE: washburn acoustic electric guitar eq & turner
Try this site:
Select the lesson on "Tuning Machines"
This looks like a good resource for information.
Posted on Dec 16, 2009
How do i adjust intonation on a peavey predator plus exp?
To adjust the intonation on a guitar you need the following. ..
a electronic tuner
and a small philip screwdriver
when you tune a string say low E you play the note open and adjust tell it's in tune
then to intonate play the low E at the 12th fret
producing a Harmonic, view the tuner it will be sharp or flat,
turn the small philip screw on the bridge adjustment
it only takes a small turn one way or the other so go slow
once the string is tuned at the harmonic note check to see if it's in tune played open, keep tuning and adjusting tell the strings are in tune open and at the 12th fret on all six strings
once intonation is set properly the guitar will sound better
really hope that helps?
Mar 15, 2015 | Peavey Music
Tip
How to string an electric guitar
I'm writing this tutorial to help new guitarists string their electric guitars.<br /><br />The first step is to purchase some strings from your nearest music store, depending on the type of music you want to play the string gage will be different. If you want to play heavier music such as metal then I suggest using a heavier gage of string. If you want to play calmer music such as indie, or maybe soft rock I suggest a lighter gage.<br /><br />Next make sure and remove <span style="font-weight: bold;">ALL</span> existing strings. The best way to take off the old strings is to simply loosen them up then cut them right in the middle with wire cutters. Then just pull the left end through the tuning knobs, and the right end through the back of the guitar (Note where the strings come out of the back).<br /><br />After you have removed all the strings its time to put on the new ones. Start with the string closest to the top of the guitar. On your string package you can reference by color which string is which. Find your string then run the sharp end through the back of the guitar in the hole relative to the string you are putting in (These holes in the back are the same holes the old strings came out of). Run the string all the way through so that it is pulled tightly into the back. Now place the sharp end of the string through its relative tuning knob at the top of the guitar. You should pull enough through so that when you pull the string up off the neck there is a gap of about one foot. Now turn the tuning knob clockwise until the string is relatively tight against the neck and it has wrapped around the knob 3-5 times. Now cut the excess string that is coming out of the tuning knob but leave about 1 inch in case you want to lower the tuning. <br /><br />Do the same thing for all your strings, then tune them with either a digital tuner or by ear if you can. You can purchase a cheap digital tuner for around $20 at your nearest music store.<br /><br />Enjoy!!
on May 16, 2011 | Yamaha Electric Guitar
Can't get the guitar tuned
Tell her to tune all strings below the pitch and always go up to the pitch, never down because of slack in the tuning keys. The gears will have a slight bit of play in them. If coming down and stopping at the right place, they will loosen and loose tuning when she lets go. Tuning from below and go up to the pitch will correct that. (more noticeable on electric) Also, I would take it to a shop to have the intonation checked and tuned if necessary.
Dec 25, 2012 | Schecter C-1 Classic Electric Guitar...
My 3rd guitar string sounds bad
Get it a repare at guitar center they have a pack of guitar strings for 5-10 Dollers they are located in Oregon Washington cailfoina if you relly want a cheep guitar that sounds good get bc rich or finder or eipcphone your guitar strings are probley getting old you have to buy a certain brad of stings that well last a year and if you need tuneing you can download an app for online tuning or you can type in online guitar tuneing I hoped this helped give me a message if you need more
Nov 25, 2012 | Dean Guitars Dean Ml Xm Electric Guitar
Unstable tuning, also goes high in pitch, I replaced tuners, permanent vibration in the sound
Look for something related to the whammy bar causing unstable tuning. The only other thing is string QUALITY and gauge. Use the recommended strings for the guitar.
Aug 25, 2011 | Gretsch Guitars G5122 Double Cutaway...
How to tune the peavy guitar
well. this may sound retarded but every guitar is the same google or youtube how to tune a guitar, also get yourself a guitar tuner there cheap and affordable
Jun 15, 2011 | Peavey Electronics Peavey Predator Plus...
Bridge: the guitar keeps getting out of tune. Should I block it with a piece of wood, making it more like a fixed bridge?
Do NOT modify the guitar. Take it to a shop where they can set it up properly if you are having intonation or clearance problems. Also the quality of strings has a lot to do with changes in tuning. It is NOT uncommon for a guitar to require tuning during a half hour of playing. This is normal, especially if you are really driving it. Temperature affects the tuning drastically as well.
Apr 11, 2011 | Ibanez RG370DX Electric Guitar
How do I change the strings on my Dean Vendetta
How to Change Strings on a Dean Vendetta Guitar
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Instructions
Things You'll Need:
* Dean Vendetta guitar
* String winder
* Guitar strings
* Electronic tuner
* Wire cutters
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
Hope it helped.
Thanks for using fixya..
Jan 14, 2011 | Dean Vendetta XM Electric Guitar
My Dean razorback V Standard keeps going out of tune and I have no clue how to fix it.
First, I don't know how long you've been playing guitar but you need to make sure the strings aren't old and/or not kept clean. The oils and skin cells from our fingers will cause strings to break down in there elasticity, therefore causing them to lose there retention (eg. memory). If you have a locking system with floating bridge then make sure your locks are tight, but not to tight as to strip or break the screws. Next, if you have a cheaper guitar, like in the $250 range, you will experience this more often than not, especially if you don't have a locking system. But just remember that guitars have to be retuned all the time (just watch live video of guitarists like Jimmy Page and Angus Young, etc.) if you play a lot and really play the instrument to the fullest (eg. Dive Bombs, EVH Horsie, Pitch Bends, etc.). Also, when you put on new strings they need time to stretch before they find that place where they retain their memory so it's a good idea to play and stretch the strings using various techniques like bending and whammy (EVH has been known to boil his strings to aid in this). Last, but not quite the least, if you find your guitar going out of tune after just a few minutes and after all my suggestions then your guitar may have a problem with its INTONATION, which you'll need to take it to a guitar technician which won't cost much and you'll be very happy with the sound. One last thing to remember, if you have a cheaper guitar without locking system they're really not capable or designed for using the whammy bar that comes with most of them---this is just a feature for helping to sell the guitar because everyone wants a whammy bar---the guitar will go considerably out of tune everytime it's used. Hope this long explanation helps.
Dec 09, 2008 | Dean Razorback Db Electric Guitar
How can i tune my electric guitar
You can go to YouTube where people have videos of guitars of various tunings.
Here's one for standards tuning.
and here's one for Eflat tuning - Use this for Guns N Roses
Here's another way - Harmonic tuning - very cool
Aug 17, 2008 | Fender Fm25dsp 1x10' Guitar Combo...
Music Logo
37 people viewed this question
Top Fender Music Experts
Michial Gueffroy
dave nyman
Level 1 Expert
Matthew Spark
Matthew Spark
Are you a Fender Music Expert? Answer questions, earn points and help others
