Question about Garmin nuvi 205W GPS Receiver
Gps doesn't switch on
Gps does not switch on anymore, that is when i switched of myself after seing that the batery was deplited.i don't where to take it to?
Plug it in to your car charger or usb cord and computer it should come on, if it doesn't its probably not fixable, make shure switch is not in lock position when you plug it in.
Posted on Jun 24, 2009
Car only starts sometimes
The start circuit from the ignition switch to neutral safety switch to the solenoid on the starter might be bad. Look for power there at solenoid or at neutral safety switch when it doesn't want to crank over.
Jan 02, 2012 | 1988 Pontiac Firebird
Tip
I BOUGHT MYSELF A FORTIS GPS NAVIGATOR AND IT CAME WITH THE ROUTE 66 SOFTWARE...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Mar 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Reverse lights do not work on 1998 Acura TL - diagnostics at shop said neurtral safety switch need replacement... is this something that I can do myself?
Yes it is. The switch is on top of the transmission under the shift cable. You will need a 13mm and 10mm socket. remove the cable, pry it if necessary. Remove the switch, pry it if necessay. replace the switch but don't tighten it down. Snug it. In stall the cable and start the car. if it doesn't start adjust the switch. When it starts, turn it off and put it in neutral and restart. If it starts tighten down the switch. Then try it again in park. If it starts then your done. The switch is fairly large and has a triangular shape.
May 18, 2011 | 1998 Acura TL
Where is the reset button on the tomtom 125 se
The on/off switch is the reset button. Hold the on/off switch down for 20 seconds for a soft reboot and 30 seconds for a hard reboot.
Jan 18, 2010 | Tomtom ONE GPS Receiver
When I charge a battery, the red light on the charger comes on but never switches to green and I dont know how long I need to charge each battery?
the green light or LED indicates or sign the the batery you are charging is already full,.so if it doesn't happen to switch ,it means that your baterry is weak and can not reach anymore the amount of current or amperes needed thats why it cant go to the highest peak of charging just like when it is new.Replace your batery and the green light will switch again if it is fully charge.
Nov 22, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
My Garmin Nuvi 710 GPS doesn't switch on
Connect your Nuvi to a PC using a USB and then hold the switch to the left for 15 seconds. It should then power up after a soft reset
Apr 02, 2009 | Garmin NUVI 710 Car GPS Receiver
Power switch not working.
If you can't you can sent it in to garmin
Feb 01, 2009 | Garmin nuvi 200W GPS Receiver
Batery problem?
The battery number is SNN5743A .
You can get it in various sites on the web.
Apr 09, 2007 | Motorola M500 MP3 Player
Garmin nuvi 205W GPS Receiver Logo
93 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
