Can't exit ask.com. help.
I want out of ask.com.
Need help exiting Netflix,on my screen
Hello, Nancy -
See my answer to the first time you asked your question:
http://www.fixya.com/support/t26844911-not_want_netflix_want_exit
Best wishes.
Dec 31, 2017 | Computers & Internet
Hitachi dcd combi tv l22dg7u engineer code required to do a factory reset.
You're asking about its 'Service mode key code", I presume.
http://schematicscom.blogspot.com/
http://elektrotricks.blogspot.com/
http://electrotechnician.blogspot.com/
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
Please visit these sites to get some details.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 18, 2017 | Hitachi Televison & Video
How do you remove case from
Here is the solution:
1) Close out any open applications and restart the computer.
2) As the machine boots up (at the eMachines logo), press F2 (to enter the BIOS).
3) Once you are in the BIOS, navigate (use the keyboard directional arrows) to the Exit Tab.
4) Under the Exit Tab, choose "Load Optimal Defaults". When you are asked to confirm, select "Y" (for "yes").
5) Save the changes and Exit the BIOS.
6) No more loud fan!! Awesome!
Sep 24, 2013 | eMachines T5048 PC Desktop
Internet download manager serial number
Step-1 : Firstly GoTo www.internetdownloadmanager.com and download latest trial version of IDM. And if you already have installed IDM on your computer then GoTo ->help->Check for updates...and update your IDM to current version.
Step-2 : It will automatically ask you for registration if you already installed IDM else click on registration, Now a new dialog(window) appears that is asking for Name, Last Name, Email Address and Serial Key..
Step-3 : Enter your Name(Any Name), Last Name, Email ID and in Serial Key paste any key from the following ->
RLDGN-OV9WU-5W589-6VZH1
HUDWE-UO689-6D27B-YM28M
UK3DV-E0MNW-MLQYX-GENA1
7ADWY-RVBYI-MPP2K-Y7BXS
And click on ok to register. You also can enter any key from your side. Means you have to enter wrong key, so enter anything
Step-4: After your click ok, it will show an error message that you have registered IDM using fake serial key and IDM will exit. Now here the hack starts.
Step-5 : Now GoTo "Computer -> C:\(Drive) ->Windows -> System32 -> drivers -> etc". Else in window paste it C:\Windows\System32\drivers\etc .. Xp and vista user cstrong>
127.0.0.1 tonec.com
127.0.0.1 www.tonec.com
127.0.0.1 registeridm.com
127.0.0.1 www.registeridm.com
127.0.0.1 secure.registeridm.com
127.0.0.1 internetdownloadmanager.com
127.0.0.1 www.internetdownloadmanager.com
127.0.0.1 secure.internetdownloadmanager.com
127.0.0.1 mirror.internetdownloadmanager.com
127.0.0.1 mirror2.internetdownloadmanager.com
After adding this, save notepad file and then exit from here.
Note : In windows vista and windows 7, due to security rea
Jul 09, 2013 | Lenovo Computers & Internet
How to make change to print on thermal paper
On the front panel of the printer:
Press SETUP/EXIT
Press NEXT/SAVE until you see a setting call PRINT METHOD
Change the setting from THERMAL TRANS to DIRECT
Press SETUP/EXIT
Press NEXT/SAVE to make a permanent save
Hope that helps.
Apr 16, 2010 | Zebra 105SL Thermal Label Printer
So no one knows how to clear or by pass the hdd password./
Yes we do but you need some special software to do that
If you can get hold of a geek with ERD Commander you are laughing.
Most of the large PC repair stores can do it but they tend to wipe the disk first and ask questions later
Jul 03, 2009 | Acer Aspire 5100 Notebook
I have eurovox ex5000 pvr would like the codes
press menu then yellow button
enter 5401
bo b8 4f 04 e6 5f 87 80
ac eb ec 07 46 49 d2 eb
then press ok exit exit any problems ask again
Dec 22, 2008 | StarTech.com StarView SV211K 2-port KVM...
Fuser
on the paper exit end of the copier you must remove 3 plastic covers
1. one that the paper exits and lays on 2. upper cover {have to slide upper half of copier to left to get to the screw} 3 small plastic cover pops out right behind where paper lays as it exits.
pull back black plastic sheet
undo 3 connectors
remove 2 screws with a phillips #2 offset screwdriver
fuser lifts up and out-very tight quarters here go slow and easy
need any further assistance just ask!!
May 06, 2008 | Canon ImageClass D880 Copier
Paper jamming
The fuser drive gear is most likely bad.
You can order one at this location.
https://www.partsdrop.com/store/
If you call ask for Britt, he will help you. Best parts service you can ask for. And NO ITS NOT ME. I just deal with them a lot and highly recommend them.
That gear is in the $15 range.
Apr 14, 2008 | Xerox WorkCentre XD155DF Laser Printer
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
