Question about Coffee Makers & Espresso Machines
It doesnot cold
How to fix cold drink model AF-18vp-n
Genesis G0-380 will not keep drinks cold.
usually calling a repairman is the best solution they use freon as coolant and the unit has to be properly charged with it .
Jul 18, 2016 | Refrigerators
Diesel in rediator
bad news, that.
is it cold there. , who cold. (numbers)
is AF at 50% or at 0?
AF= antifreeze
Jan 29, 2014 | 2008 Toyota Camry
Fridgerator not cold and freezer not freezing
You will need to clean the condensor coil. It is usually under the refrigerator on newer models and in the rear on older models. All you need to do is use a vacuum to clean it. Also try to leave some room behind the refrigerator, do not keep it too close to the wall. It needs to circulate the warm air it extracts.
Jul 15, 2012 | Roper Refrigerators
REFRIGERATOR SIDE TO COLD,FOOD AND DRINKS GET FROZEN
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My Sub Zero Model 525 is starting to freeze drinks in the refrigerator section. We've turned the temp up and it's still doing it.
replace the cold control . and clean the coils and ck the fan that its running fast enough there famous for slowing down with age .. mm hope this helps .. and thanks for using fix ya
Oct 21, 2010 | Refrigerators
Westinghouse Upside down Fridge Freezer Model #BJ504T-R5. Fridge will not go cold, cannot have a a Cold Beer out of it. Any suggestions on how to fix this problem? Freezer works OK
put the beer in the freezer for 30 mins,that should cool it nicely.....
oh, the fridge aint working, sorry,poss the thermostat or (still thinking about drinking warm beer, ugh...)have you tried cleaning the vents...
Aug 18, 2010 | Refrigerators
How can adjust the volume of water coming from the drinking spout on my Elkay water fountain?
On our Elkay drinking fountain there is a set screw underneath that you can turn to adjust the flow rate. I have detailed how to adjust the flow along with how to replace the solenoid on my blog at: http://johnfixesstuff.blogspot.com/2014/10/how-to-fix-elkay-model-ezfs81b-replace-solenoid-35981c.html John Fixes Stuff How To Fix an Elkay Model EZFS8 1B Drinking Fountain...
Mar 19, 2010 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
Upright freezer
If it has a fan in the freezer it need to be running to circulate the cold air.
If the coils are not icing up evenly from top to bottom you have a system low on freon.
The light frosting is normal.
A model number would really help to troubleshoot the problem.
Sep 19, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
NO DRIKING WATER
Replacement door is the best solution as moisture has got into the foam of the door causing the water pipe to freeze
Feb 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
