Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
I broke the red on off switch,craftsman 7 gal 1 hp
I toke the red on off switch is pcs.how i could rebuildet back ,
  • asws65 Jun 15, 2009
    I open the on/off switch then come is parts.how i could rebuildet back ,no broking pcs,just i need help to assemble the switch,thanks
  • 1,165 Answers
Use a brass bar.if u can drill a couple hole and use bolts or you could clampi t otll work fine
Posted on Jun 15, 2009
Craftsman Air Comp. 6 hp oil-less, 33 gal horz. tank - sounds really loud
Some of the craftsmen compressors have pistons that are coated on the top of the dome. Once the coating wears off, they have severe loud piston slap. If you continue to run it the way it is, it will snap the connecting rod in half or break the piston and possibly the cylinder.
Sep 21, 2017 | Craftsman 33 gal Air Compressor 6 hp...
I have a 33 gal craftsman compressor when I turn on the relay switch hums but the motor doesn't spin?
I would check the capacitor since it appears that the motor is not locked up. Here is a how to on testing capacitors;
how-to-check-capacitor
May 16, 2012 | Craftsman 33 gal Air Compressor 6 hp...
Colin just bought a like new craftsman 150 psi horizontal air compressor but there was no manual and we can't figure out how to get it started - help, please
Many of these incorporate the switch on the pressure switch. Mine has a red button that one pulls upward to enable the pump. Check around where the pressure switch is located.
Oct 29, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a 1HP/7 1/2 gal. Craftman air compressor( about 20 years old). I was using it to spray paint lawn chairs. The compressor stopped. I was to use it the next morning but for only a short time and it...
1) Check that it is not already at full pressure
2) Check that you have power coming in to the switch (20 year old power cord)
3) Bypass the switch and, briefly, plug it in.
4) Look for a fuse or breaker.
5) With the motor leads disconnected from the switch, check that you have resistance across the motor (0 ohms would be bad).
If you are not comfortable doing any part of this, don't. Check with friends & neighbors for a reputable local appliance repair company.
Jun 13, 2011 | Craftsman 1 hp Air Compressor, 4 gal. -...
Craftsman 1 HP 4 Gal air compressor runs and sounds like the air pump is working but no pressure is building up
Cold weather will freeze the water the compressor normally makes and this can prevent the switch diaphragm from releasing.... also drain the tank
Dec 27, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
Jul 21, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
I toke the red on off switch is pcs.how i could rebuildet back ,no broking pcs,just i need help to assemble the switch,
In fact the red button switch has a locking system in the cover,just force it a bit if it enters and lock again, thank god otherwise you need to change the whole pressure switch
Jun 15, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
81 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
