Question about Caterpillar D379 B Engine
Catapiller wont start
Actuater closes
I have a washer mashine kenmore oasis top load wont start
check the lid safety switch located under the top thats actuated when the lid is closed if its bad the unit will fill but not operate on any cycles
Aug 02, 2011 | Kenmore Oasis HE 27082 Top Load Washer
I have a whi lhw0050pq washer and it wont work
Yes, the door latch actuates a switch that tells it that the door is closed. until that is fixed, the unit will not run. Hope this helps!
Dec 11, 2009 | Whirlpool Washing Machines
My frigidaire stackable dryer wont turn on when i turn the start switch any clues?
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch will not activate and the dryer will not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever.
I would also check the thermal fuse as well. it is located on the vent duct or blower housing. If this fuse is damaged or tripped, it will not allow the dryer to run as well.
Jul 20, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer just stopped
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
I would also, check the Thermal Fuse as well.
Jun 25, 2009 | Kenmore 62602 Electric Dryer
Toshiba 6550 copier starts but then says close right front cover, the cover is closed, i have unplugged and plugged back in, cannot get it to work
look for the hole that lines up with the actuator that tells the machine the door is closed usually a mettle flat long part sticking out the inside of the door stick something in the hole it lines up with and see if the switch is being pushed into the on position if you can do it by hand then its a matter of repositioning that switch by reforming the switch actuator wont be easy you have to take off the cover to expose the switches
Jun 18, 2009 | Office Equipment & Supplies
Estate dryer wont engage
Check the following--
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Jun 01, 2009 | Whirlpool LER5636P Electric Dryer
Rear trunk lid wont close
There's an electronic actuator inside the trunk door. The actuator opens the trunk lid when you press either the remote keyless entry or the inside trunk release. If the electronic actuator fails it usually fails in the trunk open mode which will not allow you to close the trunk lid. You can either remove the actuator and take the car to the VW dealer, or buy a new actuator and replace it yourself. It's a tough fix, but not impossible for the mechanically inclined.
May 31, 2009 | 2000 Volkswagen Beetle
Kenmore 80 series Dryer: Door Light stays on and wont start
Mar 05, 2009 | Kenmore 800 7982 Dryer
Caterpillar D379 B Engine Logo
27 people viewed this question
Top Caterpillar Electrical Supplies Experts
gbob59
Lawrence Oravetz
lizard00420
Level 1 Expert
Are you a Caterpillar Electrical Supply Expert? Answer questions, earn points and help others
