Question about Oliso Irons
Won't turn on. acts like no power
I plugged in my iron and it won't turn on,it's as if there is no power to the iron
How do I fix my iron because it is not turning on
1. If there is sign of power (e.g. light is on), the heating element may be broken.
2. If there is no sign of power, check the power point (socket), iron power plug, cable and the power on switch. If everything is fine, you need to get it repaired.
Jun 09, 2014 | Irons
Iron plug
Bit more information would be handy? whats wrong with the plug? is there just no power going to the iron? have you tried replacing the fuse? have you tried taking the wires out and making sure there is a strong connection between the wires and the screws? if your iron isnt turning on it may not even be a problem with the plug. it could be an issue with the motherboard in the iron
Jul 04, 2013 | Irons
Rowenta Dz9080
Check or replace fuse in plug. If that don't do it, then change fuse inside iron. Make sure iron is not plugged to supply.
Apr 28, 2013 | Irons
Philips GC 2510 won't light up or heat up
If the iron doesn't heat, make sure power is on to the outlet,,test the outlet with desk lamp for to see if working. check the electrical cord, and check the thermostat + fuse inside replace if necessary.
Jan 25, 2013 | Philips GC 2510 Iron
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
Iron won't come on or heat
Hi
The problem could be the power cord or the element.
Try replacing the power cord first and see what happens.
Feb 28, 2012 | Irons
The iron will not turn on. i tryed a different location to plug it in and nothing happens.
Possible that the power cord is faulty if there is no indication at the iron. use a multimeter to check the continuity from the plug to the iron heating coil element.
it is possible that the coil has opened or the thermostat is defective.
Apr 04, 2011 | Euro-Pro Shark GI490 Iron
Shark iron wont turn on
take it back to were you got it from i think the regulator has just packed up
Jun 20, 2010 | Euro-Pro Shark GI490 Iron
Light comes on, but iron will not heat up
oliso iron turns on when plugged in green light flashes but iron will not heat up
Feb 13, 2009 | Irons
I have a Rowenta 1700 iron. The iron has started to act up. When I plug the iron in it just flashes & does not get hot. It is like it is in the stand by mode when you leave it on & don't iron...
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Oct 14, 2008 | Rowenta DZ1700 Iron
Irons Logo
80 people viewed this question
Top Oliso Irons Experts
Andrew Taylor
Andrew Taylor
ray gallant
Bill Boyd
Are you an Oliso Iron Expert? Answer questions, earn points and help others
