Question about Samsung Digimax 401 Digital Camera
Camera will not switch on
Have changed batteries but camera will not switch on
Shows error on the batteries
If your camera shows error even after changing the batteris, then it will not be an problem with the battery. Please check the setting of the camera once and switch on the camera. Also if the problem still persists, reinstall the software and try again.
Thanks
Apr 01, 2012 | Nikon Cameras
Vtech camera - will not switch on. Have tried changing baterries and sometimes can get it to switch itself on when the batteries are changed but thn it will not switch off.
Have you tried checking if the battery door is tightly secured? Make sure it's completely closed correctly, the charge could be messed up. If that doesn't work, try cleaning doors and where the battery touches the door. Some dust particles or dirt can be on there and effect the power.
Mar 08, 2011 | Vtech Kidizoom Digital Camera
Camera will not switch on only ever used twice
I presume that the KODAK shop tried the following: Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty) If no joy you will have to think about a repair. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 28, 2010 | Kodak EasyShare C1013 Digital Camera
Camera will not work, have changed the batteries, getting nothing
Things to check first are battery contact points, and micro switches that are located on the battery and memory card doors. Details on what needs to be checked may be seen here. It won't work for every case, but it's worth a try.
Dec 29, 2009 | Canon PowerShot A75 Digital Camera
Camera does not turn on
Yes there is, but it's tiny, soldered to the main circuit board, and buried deep inside the camera. But there's two other things you should first check. There's a tiny switch on both the SD card door and the battery door. These switches are closed by small plastic protrusions on the doors as they are closed. These little plastic pieces can sometimes wear down or break off. If so, you'd need to jury-rig something to make sure both switches are closed.
Aug 04, 2009 | Canon PowerShot A510 Digital Camera
We have had the casio exilim 7.2 mega pixel camera for about a year - we went to switch it on and there was nothing - so i tried recharging the battery for a few hours thinking the battery was dead - and...
i think its time to change your battery ,so try switching on the camera by changing the battery .if that not works then go for hard reset method,that is, remove the batteries and leave the camera for half an hour and then insert the battery and try
Aug 06, 2008 | Cameras
Advent MP82 camera settings
firstly buy NiMH battery , and do settings back to alcaline.
sss
Jul 21, 2008 | Cameras
Black Screen; Change Battery Message
simple! with my Canon S90 had the same problem until I changed the SD card from LEXAR for a TOSHIBA SD card and the message " Change the Battery Pack"disappeared.
Jun 27, 2008 | Cameras
Switching the camera on .
omg, i have the same problem! why does it do this?!
Jan 16, 2008 | Vivitar ViviCam 4345 Digital Camera
Stuck on change batteries
it seems that the camera section is haveing troube, may be in the lense movement or initilizing system. if the camera does not initilizes while swithcing on it turns itself off by giving low battery warning.
Nov 01, 2006 | Canon PowerShot A520 Digital Camera
Samsung Digimax 401 Digital Camera Logo
22 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
