Question about Amana AFD2535DES French Door Refrigerator
No water at water dispensor - Amana AFD2535DES French Door Refrigerator
Why is the water coming out of the dispensor not cold
Is your fridge compartment temperature in the region of 2 ~ 6 C range. Is your fridge food not going bad. Then dispensor water should be cool. Cool water tank is normally hidden inside fridge compartment. Lowest temp is around 2 ~ 6 C range.
If you keep on taking water rapidly then there is no time for the cooling tank to cool. You are just pushing house water through the water dispensor.
Oct 03, 2014 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Whirlpool Duet washer the water dispenser motor doesn't change. No water dispensed over fabric softener or bleach compartments.
1. level unit. 2. verify dispensor drawer is not plugged with detergent. 3.3.Check water hose, connections and screens in hose for blockage. 4.4.Unplug washer and check mechanical linkage installation of dispensor motor. 5. check continuity from the dispensor motor and CCU connector. 6.Check resistance of dispensor motor. get online diagnostic manual part no. W10207732A to get repair and diagnostic trouble shooting guide. Sounds complicated but is not. Also check for broken or burnt wiring/connections. Unplug and check brainbos for burned circuits/resistors. Also check your grounds. Very critical for electronics to function.
Nov 23, 2012 | Washing Machines
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
Water will not come out of the door dispenser
have you replace water filter ..... an easy test go to back of refrigerator where waterline goes int fridge and revers wires for icemaker and water dispensor and now use water dispensor it should put water into icemaker that will tell u that the switch to dispensor is working and you have a bad watervalve needs replacesed
Feb 03, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The water dispensor line clogged.
you will need to replace the line from the back to the dispensor
Nov 21, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water dispensor problem (zIss420dmass)
hmm, wonder if the flap is broken inside where the water comes out or the control board is not working properly
Jun 23, 2009 | GE Refrigerators
GE Profile Built-in Dishwasher PDW9700L
sorry for the delay. on the modificaton to the dispensor, that , im not aware of anyway. more than likely either something is blocking it from getting full spray of water of simply not enough water in the unit to full expell the detergent
Nov 11, 2008 | Dishwashers
Water dispensor does not dispense water. Ice maker works.
you have prime the system air out of the water lines this is easy to do
put a glass big enough to cover water dispensor outlet cause its going to project water out at you press and hold button till water starts to run smooth
these fridges will spit water at you when you prime the system at first cause theres air blockage in lines
May 20, 2008 | Frigidaire FRS3R5EMB Side by Side...
Water dispensor not working
Since you have water getting to the icemaker/dispenser, the most common problem I've seen is the solenoid valve is history and needs replacing. It could also be the switch that is normally activated by the dispenser itself and in turn activates the solenoid valve or the wiring in-between the switch and valve, but I have personally not seen either one of those go bad.
Jan 02, 2008 | KitchenAid KSRB22FNSS Stainless Steel
Water dispensor is not working, ice dispensor is work fine
It depends on where it is freezing. Can you determine where the freezing is? These things don't usually clog. They can develop what is called a vapor lock in the water dispenser behind the meat drawer in the refer. For freezing let me know where it is freezing.
Nov 18, 2007 | Hotpoint HSS25GFP Side by Side...
Amana AFD2535DES French Door Refrigerator Logo
32 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
