Question about KLH R5100 Receiver
Channel not working
Left front speaker not working. used other speaker wire to be sure, still not working
No surround sound on rear speakers and cant access speaker set up functions. left front channel not working when rears set up without surround
from the problem description, it sounds like a wiring/setup problem with the speakers. check to make sure you are only using the main 'a' front r & l speaker connectors. if you select speaker set a + b on the front, you will not have the rear channels. please see the speaker connection guidelines in the manual on page 13-15. make sure the audessey mike and/or headphones are not plugged in when trying to use the speaker set up function.
manual: http://www.uk.onkyo.com/downloads/1/1/9/7/8/21637363_df4adc7f5e.pdf
Jan 21, 2015 | Onkyo TX-SR307 A/V Receiver
Pioneer DEH-P47DH Front left speaker not working, if i press audio button, i get no option to adjust balance, just fader. left rear speaker works and plays as loudly as right rear speaker. Huh? bad...
Are you sure you wired up the head unit correctly? It is fairly uncommon for a audio output amplifier to blow out leaving 3 working speakers and 1 not working. So more than likely it is bad wiring or a blown speaker. Best bet would be get a digital multimeter and ohm out the speaker and see if it has continuity and is the same as the adjacent speaker. You could also try swapping the left/right channel wiring and see if the front right speaker stops working when connected to the left speaker output or vice versa.
Nov 12, 2013 | Car Audio & Video
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
Having trouble with a jvc kdr610. Just purchased from best buy. Hooked up with a gm wiring kit so all color codes are right. The left front channel is ''dull'' I tried switching the speakers from left to...
Well, very common with JVC's to loose channels, JVC's tend to burn out or, skip, or their channels die out. Easiest fix is to replace it with a Sony or Pioneer but if not an option then use the rear left channel to run both left front and left rear speakers. Wire the left front + and left rear + to the solid green rear + wire on the car harness adapter and the left negatives to the green w / black rear negative channel wire. This will be a temporary fix but you need to fix or replace the radio otherwise the speakers will draw aheavy load from the rear left channel of the radio and probably overheat or burn out on you with long time hearing or at high volumes.
Good luck.
Please rate and vote if I helped. Thanks.
Jun 17, 2010 | Car Audio & Video
My Harman Kardon AVR 220 reciever's front-right channel isn't working. I have switched the two front speakers and the right speaker works on the left channel so it is not a problem with the speakers or...
if front left is working it is possible u have a dry solder on ur right channel line. try resoldering or if u want to know exactly where dry solder is, shake gently every right channel components and connections. if resoldering does not work it is possible u have a faulty ouput amp for ur right channel. if ur not sure about this i suggest u get it checked by a qualified tech.
Apr 05, 2010 | Harman Kardon AVR 220 5.1 Channels...
Our two left speakers, front and rear will not
Check the connection on the back of the receiver. Check the balance setting, make sure that it's in the middle. Try another mode like stereo, you should hear left and right front only. Also, if your receiver has an on screen menu, check the dB levels for the front and rear left speakers. Good luck!
Dec 09, 2009 | Audio Players & Recorders
Only one speaker working on my str-de675 receiver
If the speakers themselves work fine, then the problem lies within the amplifier output. The channels can go bad after hard use, they can be repaired but it may well exceed the cost of the amp if it is not just one channel. Also be sure that you are hooking up speakers that are rated for your amplifier by matching the OHM resistance of the amplifier to compatible speakers.
May 03, 2009 | Sony STR-DE675 Receiver
I lost sound on one side of bose stereo system., Seems its the power ouput on the right side speaker, i changed speakers and the right one works when plugged into the left output. How do I open the bose...
first lets check
no need to open any thing
1) just trace the wire of working channel and plug out that and connect to opposite side of that channel
for example: if front left is not working, remove pin of front right and plug it into front left
after that listen the sound if front left is working then no need to open amplifier just check the wires of satellite speaker which is not working
how to check broken wire:
1) just observe your speaker nearly if you found any screw holes open it, if u can not find any screw holes remove front net which is fitted by press lock or any stepped groove, you can remove that and if you are removing front net you have to open speaker from casing then after you can find speaker's wire shouldered or bolted to it just check wire and go on after that u'll be sure that weather your speaker is failed or wire!!!
enjoy!!!!!!!!!!!!!!!
(don't forget to rate)
Jan 04, 2009 | Bose Acoustimass 15 System
Left Channel Not Working.
Has it ever worked?
Try this - connect one pair of its speaker wires at a time and test it. Watch the polarity.
• Make sure all cube speaker arrays are connected to the proper terminals according to their
position in your room.
• Check to be sure all wires are connected to your surround receiver with the proper polarity
(+ to + and – to – wires). Incorrect wiring can result in a total loss of module output.
• Correct any wiring problems before you plug in your receiver and turn it on.
How do you know the receiver's Left channel isn't the fault? Sounds like a source issue.
Jan 04, 2009 | Bose Acoustimass 16 Speaker
No sound from Front Speaker
take amp to a workbench, have a test speaker in hand, touch the speaker wires to each channel to see if all channels work. take each speaker to the amp and temporarily hook one at a time to see if any speaker is bad. if you eliminate the hardware, you know it's the wires in between.
Mar 02, 2007 | Mission 700 Main / Stereo Speaker
KLH R5100 Receiver Logo
42 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
